Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
NX assisted 1/4 mile...
Old Aug 7, 2004 | 01:15 PM
Ellinaras's Avatar
Ellinaras
Default NX assisted 1/4 mile...
Well guys I have a 99 FRC C5 with the following mods:
1. Blackwing filter
2. Ported T.B
3. Off-road Magnaflow X-pipe with the Borla straight pipe system
4. Hurst Shifter
5. NX wet kit with the "75 shot" on
My 1/4 mile results on regular tires (Nittos but not the DR's) were:
Reaction: 1.059
60 ft : 2.217
1/4 ET : 12.844
1/4 MPH : 119.16
I am about to bump the shot to 100 but how much do you think I can improve with the current set-up if I get some Drag Radials ???
Old Aug 7, 2004 | 02:24 PM
JOHNNY P.'s Avatar
JOHNNY P.
From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
Get the Drag Radials A..S.A.P. ! You should be running 12:70's with a Drag Radial on motor alone with 1.70 60 ft. times , Then take it from there . Your 60 ft. times are way off and need improvement before even touching the Bottle.
Old Aug 7, 2004 | 03:52 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Last weekend I was staged on a pro tree, my opponent fouled badly; the win light came on in my lane before I launched. Why beat on the car with an automatic win so I made a very mild start - no revving or spinning. My 60 time was 2.3 seconds....
Old Aug 7, 2004 | 08:08 PM
Forza1's Avatar
Forza1
1. Blackwing filter
2. Ported T.B
4. Hurst Shifter
Reaction: 1.059
60 ft : 2.217
1/4 ET : 12.844
1/4 MPH : 119.16
Wow man, you suck at driving that thing! You should be able to nip into the 11's.
When are you spraying the nitrous? Is traction your only problem?
Old Aug 7, 2004 | 09:07 PM
90 droptop's Avatar
90 droptop
With that MPH, you should be runnng mid 11's easy.
Old Aug 7, 2004 | 10:11 PM
MC TORCH RED's Avatar
MC TORCH RED
i trap 117's and run 11.70's e z.
Old Aug 8, 2004 | 05:05 PM
oufan2929's Avatar
oufan2929
I have nearly the exact same setup as you. I went 11.75 at 117 w/a 100shot. Just get some more seat time and don't listen to what some of these jerks say on here. Some of them act like they are pro drivers i.e. "Wow man, you suck at driving that thing!" Don't be discouraged. If you can get those 60ft. times down to 1.8-1.9 on your street tires, you should hit 11's for sure w/a 100shot. Get some DR's and you'll see some 1.6's-1.7's after some practice. You'll get there. Are you auto or 6sp.? Launching (60ft) is the key to everything!
Old Aug 8, 2004 | 05:19 PM
JOHNNY P.'s Avatar
JOHNNY P.
Old Aug 8, 2004 | 11:06 PM
IMQUIK's Avatar
IMQUIK
Speed shift it!
Or get an A4.
Old Aug 9, 2004 | 01:21 AM
Ellinaras's Avatar
Ellinaras
Thanks for the replies guys...
I do have a 6-speed car and I also always powershift it but traction seems to be my biggest problem..
Even if I get out of the line decent...I loose traction again when the nitrous hits...I have a RPM window switch that kicks in at 3000 rpms and when that happens I always go a little sideways...
Yeap drag radials seem to be a must on the things I would like to add...
As for the dude that said "I suck at driving that thing" ...you need to try the Alamo Dragway in San Antonio with no DR's and see what's up...
Thanks again for the replies
Old Aug 9, 2004 | 01:22 AM
NASTY97C5's Avatar
NASTY97C5
Good advice! Drag radials are a must!
Old Aug 26, 2004 | 06:21 AM
Evolution's Avatar
Evolution
Work on your launch. Improve that and you will see alot more than a high 12.
DR's would be a start.
Old Aug 27, 2004 | 11:09 AM
BayouVette's Avatar
BayouVette
i would try to get used to your track first..
To NX assisted 1/4 mile...
