Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
408ci results
Old Sep 30, 2004 | 09:18 PM
joe03z06's Avatar
joe03z06
Default 408ci results
Well after a long 4 months of waiting, stress and headache, my motor was finally put together and strapped onto the dyno.
Here are the results from our 408ci stroker. Vehicle is a 2003 Z06.
Here is the setup:
Engine: 408 cubic inch iron block
Lunati 4.00" crankshaft
Lunati Billet 6.125 connecting rods
Wiseco Custom forged pistons 11:0 to 1
Icon custom grind hydraulic cam
Rollmaster Double roller timing chain
Comp Cams 7.400 push rods
Crane Cams lifters
LS6 Competition cylinder heads
Ferrea Stainless 2.08/1.625 valves
Jesel Rockers 1.7
ARP main studs
ARP head studs
Fel-Pro gaskets
LSX 90mm intake
Custom 90mm billet throttle body
Kooks 1-7/8" stainless headers
3"x 3" Off-road X-pipe
Corsa Tiger Shark exhaust
Spec Stage III clutch
Fidanza Aluminum Flywheel
Donaldson Blackwing Intake
Billet output shaft
Car was dynoed today on 19" CCW's and made 527 rwhp @ 6400 rpm and 495 ft/lbs. @ 4800 rpm, uncorrected. This was with a conservative 22 degrees of timing. We decided to go ahead and try the nitrous, which was jetted for 200 hp with a bottle pressure of 900 psi and it put down 707 rwhp @ 6400 rpm 660 ft/lbs. @ 4900 rpm. The above numbers were produced through the mufflers. No other tricks were done to try and get an unrealistic number. Dyno graphs will be posted in the near future.
Old Sep 30, 2004 | 09:35 PM
big bollas's Avatar
big bollas
Kick AZZ
Old Oct 1, 2004 | 12:03 AM
90 droptop's Avatar
90 droptop
Nice numbers, very similar to what I have going on. What are your cam specs?
Old Oct 1, 2004 | 04:01 AM
kumar75150's Avatar
kumar75150
what were the corrected numbers?
Old Oct 1, 2004 | 09:33 AM
joe03z06's Avatar
joe03z06
I'll check and post them later
Old Oct 1, 2004 | 09:49 AM
GOOSE JR.'s Avatar
GOOSE JR.
Big cubes are the the greatest, all the standard cubes work great but nothing drives like a large displacement engine. Do you plan on driving it on the street? The thunder of your new toy must be montrous! YES it's the nuts. Gary
Old Oct 1, 2004 | 10:39 AM
N2 TRBL's Avatar
N2 TRBL
Frickin' nice mang ...time for the quarter.
Old Oct 1, 2004 | 11:21 AM
NXTFAZE's Avatar
NXTFAZE
Very nice......
Old Oct 1, 2004 | 09:54 PM
joe03z06's Avatar
joe03z06
The car is VERY streetable, i dont use it as a dd though. I drive a acura integra to work. I fish alot so i need a hoopty as a dd. Thanks everyone for the compliments
Old Oct 2, 2004 | 11:06 PM
phear_this_mind's Avatar
phear_this_mind
On another note, I often times contemplated buying a honda just so that I can kick it and dent it whenever I want. Drive it up curbs, run into shopping carts, throw rocks at it. Basically treat it how it deserves to be treated (being a honda and all).
But then, because of the embarassment (of being seen in the honda) I would have to constantly explain WHY I got it and encourage stangers to kick it.
No guys, seriously, I have contemplated this ... ... ...
To 408ci results
