Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Request Input on Expected Performance
Old Oct 6, 2004 | 10:32 PM
BIGMAC's Avatar
BIGMAC
So far my best time has been 13.43 @ 105 MPH with a 2.08 60ft time with my '98 A4/2.73 Coupe. Stock except for Intake, X-Pipe, and Borla Stingers. On the way:
BPP Long Tube Headers
3.42 Gears
PCM re-program ("Superchips")
BFG Drag Radials
What sort of performance should I expect?
Thanks.
Old Oct 7, 2004 | 12:43 AM
WardVette's Avatar
WardVette
3.42 Gears
BFG Drag Radials
Thanks.
I'll make a wild guess just to start things off... 12.8 @108
Old Oct 7, 2004 | 02:29 AM
phear_this_mind's Avatar
phear_this_mind
May I STRONGLY suggest a Yank 2800 stall converter while you're at it?
Old Oct 9, 2004 | 09:09 AM
BIGMAC's Avatar
BIGMAC
Stall Converter
I have gone back and forth on the stall converter. I understand the benefits, but I am concerned about shortening the transmission life and breakage to other driveline components (output shafts, etc.). I know that if I do it later I wasted the labor savings of having it done at the same time as the gears.
I plan to enjoy my upgrades so far and continue to evauate future mods. TC is at the top of the list.
Old Oct 9, 2004 | 11:35 AM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Old Oct 9, 2004 | 11:36 AM
Mitch C's Avatar
Mitch C
You really should reconsider installing a T/C at the same time you install your 3.42 gears. A high stall T/C is a must have for an A4. Depending on how you drive your car tranny life should not be shortened especially if you install a good tranny cooler. If you beat on your car alot you can expect to have to replace the stock tranny even with the stock converter.
Old Oct 9, 2004 | 02:24 PM
02blueelectron's Avatar
02blueelectron
i have almost the same mods but with a ss3200 yank converter.it drives almost like stock. 1/4 mile 12.69 @ 108.5 mph.......
To Request Input on Expected Performance
