Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Sooooo close to 11's !!!
Old Nov 7, 2004 | 07:16 PM
msghuff's Avatar
msghuff
Default Sooooo close to 11's !!!
Ran my best today with the new cam
1.82 60ft
7.81 1/8th
92.02 MPH
12.05 1/4
116.94 mph
I also ran a 12.33@118.23 and 12.38@118.42 both with a 2.0x 60ft Im still on street tires and the stock clutch.
The car feels much better with the TR224 cam, but showed hardly any gains on the Dyno over the 221/221 I had in there. I always use the same dyno after each mod to track gains/losses, verify tune ect.. but I honestly think that the dyno is in need of calibration, I got 370 Rwhp this time but trapping 118 mph. another friend is running low 11's@122 and dynoed 365 on the same dyno two days prior. Oh well the dyno is only a tool...the track/street is what counts!! Ive got Two more times to try and break into the 11's before I deploy. Wish me luck!!!
Old Nov 7, 2004 | 11:36 PM
mdhmi's Avatar
mdhmi
Great ET for the MPH.
Mark
Old Nov 8, 2004 | 05:46 AM
KapUSMC's Avatar
KapUSMC
Originally Posted by msghuff
1.82 60ft
7.81 1/8th
92.02 MPH
12.05 1/4
116.94 mph
I got ya beat... My best was on Friday night...
12.011 @ 117.70 1.823 60 ft @ 1500 da
Sucks to be that close... Oh well, hopefully we will both get it next time.
Old Nov 8, 2004 | 07:23 AM
robz's Avatar
robz
You'll get it bro!
Old Nov 11, 2004 | 03:14 PM
msghuff's Avatar
msghuff
What did you put down on the dyno? I 'm just wondering how the numbers compared to your Mph. Thanks
Old Nov 11, 2004 | 07:05 PM
KapUSMC's Avatar
KapUSMC
395rwhp/390rwtq.. Im having some cam issues.. Probably gonna go with a new one, and that number should go up quite a bit. Any idea what the DA was on your run?
Old Nov 11, 2004 | 07:57 PM
Geneus's Avatar
Geneus
Get a CCW drag package, and you'll be in those 11's with no problems!
Old Nov 11, 2004 | 08:06 PM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
1.82 60ft
7.81 1/8th
92.02 MPH
12.05 1/4
116.94 mph
The car feels much better with the TR224 cam, but showed hardly any gains on the Dyno over the 221/221 I had in there. I always use the same dyno after each mod to track gains/losses, verify tune ect.. but I honestly think that the dyno is in need of calibration, I got 367 Rwhp this time but trapping 118 mph. another friend is running low 11's@122 and dynoed 395 on the same dyno two days prior. Oh well the dyno is only a tool...the track/street is what counts!! Ive got Two more times to try and break into the 11's before I deploy. Wish me luck!!!
Good luck hitting your goal and be safe on your deployment!!
Old Nov 11, 2004 | 10:27 PM
vetterlatethannever's Avatar
vetterlatethannever
Amen!!!
Old Nov 12, 2004 | 01:08 AM
msghuff's Avatar
msghuff
no idea but it was cool out what cam are you thinking about?
Geneus: Get a CCW drag package, and you'll be in those 11's with no problems!
Yesterday 07:05 PM
I want to be able to race just like I drive it on the street so no slicks or funny suspention set ups
Old Nov 12, 2004 | 12:49 PM
KapUSMC's Avatar
KapUSMC
Yesterday 07:05 PM
Im not quite sure yet... Im going to wait till after famaso on Dec 4 before I make any cam change. I wanna hit 11's on the current set up first. I will probably go with somewhere around the same came Im running now (228/232 113 LSA), but with a different grind. Mine is an old Comp Cam, not the XER grind. My tuner thinks that its costing me between 25-40 hp on the top end. Its great under the curve, but just kind of lays down when it gets to the top end. I too am not running ET Streets or skinnies up front... I run what I drive it to the track on (BFG DR's) so I know what you mean on that one. Hopefully in 3 weeks, I will have a new avatar
Old Nov 13, 2004 | 12:38 PM
IFLUBYU's Avatar
IFLUBYU
Just hang in there, you'll get it.
I was running 12.08 and really wanting to pop an 11. After looking closer at my dyno, I dropped my shift on 2-3 to 6200 and the 3-4 to 5800. This got me down to 12.03-12.05. What got me the rest of the way was lining up with a Honda at the Import/Domestic shoot-out!
So line up against someone you want to beat so bad it hurts, I never shifted so quick in my life.
My drag radials are past beeing shot, but props to you to getting that close on street tires and lower hp, well done!
I come from the Old School, back in the late 70s early 80s the rule on the streets where I ran was race it like you drive it, and no nitrous. I've hadn't drag raced since early 80s till I bought this in 2000 and I am just now beginning to realize while those old ideas are quaint, it doesn't hold water if no one else is doing it. So I believe I will probably break down and buy a CCW drag package. You get tired of some guy in a CRX running 10s on slicks and juice being able to run in the same class as you whipping you, and all you can do is try to even the playing field.
Let us know when you hit that 11!
To Sooooo close to 11's !!!
