Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
cartek twins
Old Nov 9, 2004 | 10:35 PM
washguy's Avatar
washguy
Default cartek twins
Hi Cartek Guys! ive been following the tt that you were running. I havnt seen any more track reports as of late. Ive seen that the air is great now,and the season is not far from ending,but unless ive missed a post...I havnt seen any more runs of the tt for a long while.
whats up with that monster? Wash
Old Nov 9, 2004 | 10:48 PM
Tsab's Avatar
Tsab
Paul was at the track Saturday, and they are still dialing it in. I'm sure that 9's are just around the corner for that machine. Maybe this weekend at the Vette Viper shoot out at Atco.
Old Nov 13, 2004 | 10:25 PM
robz's Avatar
robz
9.90 on the lowest possible boost setting, letting up at the line, in a 20knot sustained headwind so far.
Old Nov 14, 2004 | 03:13 AM
LS1LT1's Avatar
LS1LT1
Old Nov 15, 2004 | 10:06 AM
Dave_Busch's Avatar
Dave_Busch
It has been a learning curve. The cold air only makes it harder to get traction. Basically the 26" ET Streets spun to a 10.4 and then we went to the 28" ET Streets. Then the clutch said, "I don't think so". We had a custom twin disc built, clutch holds, tires and out put shafts don't. Then we broke 2 pass side and one 300M transmission out put shafts. Another 300M transmission out put shaft and a custom built pass out put shaft were installed. And then we went 9.90 on a not so perfect run but no breakage. We hope to run it this Friday and I know we can hit the 9.60 mark.
Old Nov 15, 2004 | 08:22 PM
Tsab's Avatar
Tsab
Dave...that thing will be running 8's next year, its just going to take a lot of tuning and dialing.
Old Nov 16, 2004 | 11:23 AM
Dave_Busch's Avatar
Dave_Busch
It has enough power on the high boost setting but I think 8's are pushing it on a 6spd car.
Old Nov 18, 2004 | 01:06 AM
CraZee ZO6's Avatar
CraZee ZO6
Will you be running at the rental in atco this Friday? If so let me know, I plan on going few of my friends are running. PM me if you want.
Old Nov 28, 2004 | 03:51 AM
LS1LT1's Avatar
LS1LT1
Or even 9.8 at this point, so far.
To cartek twins
