Don’t forget, we can still flatmill a 72 cc chamber as low as 65 cc’s (the same figure as a stock LS6 head), but any of you looking for a higher compression (11 to 1 etc.) stock displacement shortblocks will unfortunately have to wait an additional 3-4 weeks or so till we start taking deposits on our 62 cc version which has the capacity to be milled into the mid 50 cc range.
AFR will have a 225 to suite your NA needs very shortly - if they don't already.
Originally Posted by dads01dream
That's *exactly* why I'm interested in a good set of heads, to compliment my D1-SC setup!!!
Me too - between a mild cam and the AFR 225's to go along with my D1SC ... mmmmmmm.
There is a thread called "The AFR Thread" started by Tony Mamo. He indicated that he is going to post any updated information under that thread when it is available.
