FRC vs Z06
Anybody with actual results?
Would a cold air and some longtubes get it there? Maybe add some dyno tuning?
The FRC came with the LS1 and the Z06 has a LS6
LS6 = different heads and cam, not to mention all the handling upgrades, shocks sway bays etc...
I have read a lot of posts where guys buy a FRC and turn it in to a Z.
Does that make sense?
The Z06 is a sweet car...but I am fine with a normal FRC....plus some ponies. I know heads and cam will duplicate it easily enough....I am wondering if you can come close with boltons.
Maybe I should phrase the question differently...I will try a new thread.
Keep the FRC and mod it right. If you were to buy a z06 you need to eventually swap the cam and upgrade the heads anyway to keep your head above water these days so you may as well start with the more unique of the two cars.
Unless you like all the badges, screens,etc...
There are two things to remember.
1. Power
2. Gearing
To get more power, as many have already indicated, you can take an FRC or Vert (my personal choice), and add a head/cam package or an SC package and simply beat the Z06 in straight line competition.
Now, remember, the Z also has a different tranny which helps with gearing. Essentially, it changes the 3.42's to effectively 3.73's. So, if you aren't interested in simply beating a Z in the quarter, then also upgrade gears and the Z will be destroyed!
FWIW, if you decide to go with forced induction, which is still going to be cheaper than the cost difference between a Z and a FRC, the LS1 is a better choice because it's a lower compression ratio which means you can run more boost safer.
I bought the car with a Ls6 intake, roughly polished TB, blackwing, TPIS LTs with factory cats and added GHLs. the car dynoed 340 rwhp/340 rwtq.
Then I bought:
01 Z06 wheels purchased $700
Crashed 94 built M12 $2g stg (4?) Viper shift forks, chryoed etc etc
04 Z06 Suspension was roughly $1g shocks, springs, sway bars with end links.
I have a set of bare Z06 heads $800
So if you want H&C with aftermarket cat back but want a Z06 conversion you're looking at $4,500 in parts bought used off the forums for the FRC plus cam, gaskets, porting, and install which you would need on a Z06 if you wanted H&C.
If you want cosmetics, the guage cluster changed back grounds but is scaled the same, Z06 stetched on the seats, front screens, rear ducts, paint the calipers red, and badges on the fender.
I ended up doing H&C and picked up some TEA stg 2 5.3s on a deal I couldn't pass on. Then added a futral Fm11 (228/230 112+4) cam.
The 04 Z06 setup does handle great. and is worth the uprgade. However shocks and 01+ sway bar end links alone may get most drivers what you want. I did everything at once.
Some don't like the Z06 ratios in th M12. I like the lower M12 ratios with a 3.73 as it keeps a little more top end over a M6 with 3.90s but has the low end gearing to get off the line. Many like the M6 with 3.90s as it keeps the gears closer.
I think I came out with a car I love for less $$ than a Z06. #s in sig.
