Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Results after mods
Old Dec 5, 2004 | 07:32 PM
kconklin's Avatar
kconklin
5th Gear
Default Results after mods
Here are the results I got on my 03, M6 Vert. Stock it Dynoed at 311 RWHP, 337 RWT. After K&N cold air intake, 160 degree Tstat, cam, valve springs, corsa x pipe, corsa cat back exhuast, 410 gears, hurst shifter and dyno tune, I got 352 RWHP and 337 RWT. I didn't go with too aggresive of cam as I wanted good driveability. Work was done by DyonTech Engineering in Ft Wayne, IN. Is this what you would expect with these mods? Its alot of fun to drive. Will probably be buying some new rear tires sooned then I expected.
Old Dec 5, 2004 | 09:10 PM
cliffkh's Avatar
cliffkh
hard to tell if that is in line without some cam specs - but seeing you have no headers and assuming it is something like a 224 or less that is about what I would expect. Headers will add a lot of power on a cammed car - even a small cam.
Old Dec 5, 2004 | 11:06 PM
Mitch C's Avatar
Mitch C
Old Dec 18, 2004 | 10:07 AM
ROD BROWN's Avatar
ROD BROWN
Default What I got
You can read below what I have in my car and the dyno results.Remember,every car is different.You can have the same mods in two different cars of the same make and model,but the end results MAY differ by a large degree.
Old Dec 19, 2004 | 01:14 AM
SamReidland's Avatar
SamReidland
1st Gear
Default My Results
Picked up my 99 from 21st Century Muscle Cars this afternoon. They dropped in a cam, Z06 exhaust back to my Corsas, replaced my MAF and did a LS1 edit. The dyno run before the parts and tune was SAE 319/320, after 371/342. Torque seems a little low, but the HP numbers impressed me. SOTP is very good. All in all I am very happy with it.
To Results after mods
