Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
98 vert/ 95000 mi UPDATE...
Old Dec 7, 2004 | 06:43 AM
Nukecop's Avatar
Nukecop
St. Jude Donor '05
Default 98 vert/ 95000 mi UPDATE...
results, G5X3 cam installed,comp cams 92 valvesprings, seals etc.. comp cam 7.400 pushrods , F.A.S.T. 78mm manifold, ls1 edit and dyno, 363 rwhp, still more tweaking to come this week by AZPOWERANDSOUND, tempe. pleased so far. 98 a4.
Old Dec 7, 2004 | 09:38 AM
Mitch C's Avatar
Mitch C
I did not see a hi stall T/C listed in your mods. If you don't have one you will definately need one with that big cam. I would also want at least 3.42 gears to go along with my T/C.
363 RWHP with that big cam is on the low side. I would say somemore tweaking is definately needed. Good Luck!!!!!
Old Dec 7, 2004 | 10:00 AM
Nukecop's Avatar
Nukecop
St. Jude Donor '05
Default 98 vert/95000mi
protorque 2400 stall and zo6 3:42 diff, what range should i be in? first time for this and trying to get some feedback, this is an A4 with everything else i think i need and have, daily driver no track time, want too keep driveability, and some kind of decent gas mileage. any and all input would be greatly appreciated.. thanks all.
Old Dec 7, 2004 | 10:09 AM
Mitch C's Avatar
Mitch C
I had a PT2400 in my car at one time, it is a good little converter. But with that big cam you need more stall to get the best performance out of it. I would say you need 3500 stall minimum with 4000 stall or more being even better with that huge cam. If I were you I would take a good look at the Yank SS4000. Even though it has alot of stall it still will give you decent driveability. Going to a numerically higher gear ratio like 3.73 or 3.90 will also help your driveabilty and performance. If you feel a 4000 stall is more than you want the Yank SS3600 or SS3800 would also be alot better than your current PT2400. Good Luck!!!!!
Old Dec 11, 2004 | 04:09 PM
Y2K1 SS 5.0 THIS's Avatar
0Y2K1 SS 5.0 THIS
Former Vendor
I personally prefer the SS3800 for that cam... anything bigger on the street and its gonna be a smokeshow anytime he hits the gas!
Oh, and the numbers were unlocked on a VERY conservative tune set for 89-91 octane meant to last year round without editing in our 120 degree summers... we could have gone more agressive but then that defeats the purpose of a no maintenence daily driver
To 98 vert/ 95000 mi UPDATE...
