Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
C5 Rwhp?
Old Dec 9, 2004 | 10:56 PM
StoCK's Avatar
StoCK
Default C5 Rwhp?
Around what rwhp does the manual '00 C5 make stock?
Old Dec 9, 2004 | 11:16 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
They average around 300 SAE corrected
Old Dec 10, 2004 | 03:02 AM
Mitch C's Avatar
Mitch C
300-310 Rwhp
Old Dec 10, 2004 | 08:06 AM
Fastbasser's Avatar
Fastbasser
Seems it depends on where you live on this site!
Old Dec 10, 2004 | 05:19 PM
Jack Behrle's Avatar
Jack Behrle
My '99 FRC makes 326hp/330 torque after dyno tune.Stock except for MAF-T, BW, X-Pipe.
Old Dec 10, 2004 | 05:40 PM
StoCK's Avatar
StoCK
What does "SAE corrected" mean?
Old Dec 11, 2004 | 09:03 PM
shurite44's Avatar
shurite44
Default corrected
That means the dyno numbers are corrected to the standard atmosphere of 60 degrees, barometer 29.92, and sea level.
Old Dec 11, 2004 | 09:26 PM
CarsRFun's Avatar
CarsRFun
just dynoed my dads 04 w 981miles on it, 301 to the wheels.
Old Dec 12, 2004 | 05:55 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Default Sae
Probably stupid question but, will the numbers be smaller or larger when your car is dynoed SAE versus a normal dyno.....
Old Dec 12, 2004 | 06:11 PM
JerryL's Avatar
JerryL
"Normal dynos" usually provide SAE corrections. Some guys don't like to quote them if they are lower than the uncorrected numbers. If the atmospheric conditions are better than standard (lower temps and/or higher pressure) the horsepower/torque numbers will be higher than SAE corrected.
To C5 Rwhp?
