Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
DTE Differential Brace Questions
Old Jan 26, 2005 | 05:00 PM
The One's Avatar
The One
Ok guys. I've talked to RPM and I have information for you. However, RPM is not a supporting vendor so I can't post anything else or the mods will delete it. If you are interested in the details. Send me a PM.
I can tell you that the rear suspension must come down to install this brace. For some of you, I know that'll be a deal-killer. For the rest of you, PM me and I'll fill you in.
Old Jan 26, 2005 | 05:08 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Does the RPM brace have any bracing on the bottom of the diff?
Old Jan 26, 2005 | 05:23 PM
The One's Avatar
The One
No. I'm guessing, but I would say that it's because the differential torques over in the opposite direction. The bars on top keep the diff from pulling apart from the tranny. On the bottom, the diff is pushing towards the tranny under a heavy torque load. No need to reinforce that spot. Unless you're doing burnouts in reverse! Just kidding...
By the way, I base this on the fact that all the busted casings I have seen have had the top mounting points broken off. Never seen any break on the bottom. Again - just my opinion - but it makes sense in my head!
Old Jan 26, 2005 | 05:59 PM
3XBlack6spd's Avatar
3XBlack6spd
PM Sent.....
Old Jan 26, 2005 | 09:46 PM
97 SC Cobra's Avatar
97 SC Cobra
I'm in.
Old Jan 27, 2005 | 07:34 AM
SS930's Avatar
SS930
Originally Posted by 3XBlack6spd
PM Sent.....
Old Jan 27, 2005 | 04:34 PM
99Z51R's Avatar
99Z51R
Cruise-In III Veteran
St. Jude Contributor '04
Good price, and free shipping You can e-mail RPM directly with any questions, or to order. They have 5 made up and ready to go.
Old Jan 27, 2005 | 06:57 PM
97 SC Cobra
I sure hope this flies. Anyone thinking of drag racing their vette should consider this, just ask anyone who's trashed their diff and trans.
Old Jan 29, 2005 | 06:41 PM
Amerkin's Avatar
Amerkin
Originally Posted by The One
Here's my typical launch.[/URL] The car you hear winding up for a 6K launch is mine. A rear end with a lesser brace would not take too many of these...
What do you have for mods and what does it run? BTW, nice run.
Also, I have the DTE brace and have broken a stock output shaft in the diff on 16" cheater slicks. The track was merciless that day taking down a total of six Vettes. (Three output shafts, one tranny main output and two clutches. ).
Old Jan 29, 2005 | 06:59 PM
The One's Avatar
The One
Thanks. It's an '01 6-speed, heads/cam (from RPM as well, coincidentally ), 4.10 gears and all the other typical bolt-ons. Stock bottom end and water pump, though.
Unfortunately, these braces do not protect against broken output shafts. You better have a hardened one in there if you're going to race it. The brace simply helps to keep the gear casing from separating from the tranny, which in turn would take out your tranny main shaft. Been there, blah, blah, blah...
Old Jan 29, 2005 | 07:03 PM
The One's Avatar
The One
Thanks. It's an '01 6-speed, heads/cam (from RPM as well, coincidentally ), 4.10 gears and all the other typical bolt-ons. Stock bottom end and water pump, though. Best time is 11.1@124. Got a new cam in there and I'm hunting down that elusive 10.9x slip.
Old Jan 30, 2005 | 08:06 PM
petercln's Avatar
petercln
mp sent
Old Feb 2, 2005 | 02:09 PM
  #33
The One's Avatar
The One
Thought I would post this update:
RPM had received only 9 requests to join the GP. They had decided to go ahead with 9 instead of the required 10 anyway. But when they started contacting the buyers, a couple backed out. If there is no more interest, this GP will not happen, unfortunately. Sorry guys...
Old Feb 2, 2005 | 04:09 PM
  #34
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
shoot me a pm on the details.
Old Feb 2, 2005 | 04:20 PM
  #35
97 SC Cobra
That sux man. Hopefully a couple guys will take their spot soon! RPM will get my business anyway, at least they tried.
Old Feb 2, 2005 | 04:35 PM
  #36
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Is this what your diff looked like?
Backtrack for more.
PM me a price too
Old Feb 2, 2005 | 09:57 PM
  #37
z06pdq's Avatar
z06pdq
From: Only in America can you get paid that much money for crying --the state of Texico
me too!
To DTE Differential Brace Questions
Old Feb 2, 2005 | 10:38 PM
  #38
The One's Avatar
The One
Originally Posted by z06pdq
me too!
I've PM'd all of you back with the info. Let me know if you didn't get 'em.
Old Feb 3, 2005 | 07:40 AM
  #39
SS930's Avatar
SS930
Can someone give me details on what exactly needs to be done to install this brace... including the time it takes for a DIY? Is a lift needed?
Dropping the rear suspension is what killed it for me, but I will reconsider it if it's not that much of a PITA. I assume a 4 wheel alinement is required after dropping the suspension???
BTW, how much of a savings is this GP?
Old Feb 3, 2005 | 08:04 PM
  #40
Pumba's Avatar
Pumba
Originally Posted by 97 SC Cobra
I have looked into the RPM brace and have heard good reviews by some forum members running much faster than my stock Z. The RPM brace is only about 12lbs which is a bonus. Since DTE isn't offering a GP i'd be more than willing to go with the RPM.
There is a method to take over 6 lbs. out of the DTE Strut:
