Presuming no change in power to the car I would expect you pick up 1 or 2 tenths from converter very little 60 from the tires and you will probably lose because they are taller.
hi the reason im thinking of changing to yank was because they said i would pick up 4/10s and reason for slicks was i was spinning drag radials off line when i hit nos if im wrong id be saving a couple grand thanks for input
From stock to 3600or 4400 4 tenths I'd say no brainer but from 3000 no. That is to say a 4400 is worth .8. I may be wrong but am quickly appraching 1000 passes and 5 years of track time.
On the tires, if you are spinning you should theoritcally be better off with the slicks. However, a taller tire reduces your gear and thus your ET so what you pick up in hooking you may give back because of the tire.
I swap from drag radials to ET Streets about the same height and my et different is .01 to .02 in my 400 rwhp A4 with 4.10 and 4400 stall
I don't use nitrous so I may be a little off as I would not know how it behaves. I know I have seen some adds for nitrous converters so maybe it is a different animal
yes thats what yank is saying,the 4200ssis a nos converter and i will now get ET STREETS,i will let you know how i make out.
