Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Best way to launch?
Old Jan 11, 2005 | 01:42 AM
VLVETTE's Avatar
VLVETTE
Best way to launch?
2004, A4, 3.42, Vararam, LS1 edit on run-flats? (Want my buddy and his Lightning to simmer down alittle)
Old Jan 11, 2005 | 02:02 AM
quick99ls1's Avatar
quick99ls1
drop the tire pressure a little, do a burnout to get the tires sticky, and stall the car to about 1000rpm and then launch, thats what i did with my friends a4, anything hire than that would make the tires spin alot once i took off, but then again he had 3.73 and exhaust and intake. but that just how i would do it, do some practice runs and see what works best, im sure other forum members know alot about this too good luck
Old Jan 11, 2005 | 02:27 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I have seen some fast Lightning, you might not have a chance. If you have a stock torque converter, you might be toast. Most races are won off the line. From what I have heard, it very hard to launch with run flats.
Old Jan 11, 2005 | 08:52 AM
Automag928's Avatar
Automag928
IMO, Don't do a burn out with the stock run flats...I never fully understood this until I went to APE with my friend last year... Leaving their shop, he did a nice burnout on street tires...What happens is the rubber that comes off in little tiny ***** forms a real slick surface on the tire, giving you even less traction than had you not done a burnout at all. At the most, just spin 'em real quick to get the dust off, but nothing more.
Honestly, to race a stock lightning with your mods, I'd just ease into it, you shouldnt have too much trouble.
Old Jan 11, 2005 | 08:06 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
sideways out of the hole
Old Jan 12, 2005 | 11:40 AM
simpleman68's Avatar
simpleman68
To Best way to launch?
