Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
1/4 expectations?
Old Jan 13, 2005 | 11:41 AM
StoCK's Avatar
StoCK
Default 1/4 expectations?
What do you think I will run in the 1/4 with 400rwhp, drag radials, upgraded drivetrain (shifter, clutch, flywheel) and a 3.73 rear-end ratio?
Old Jan 13, 2005 | 12:20 PM
mdhmi's Avatar
mdhmi
11's @ 120ish.
Mark
Old Jan 13, 2005 | 01:10 PM
CarsRFun's Avatar
CarsRFun
depends on if you know what you are doing.
Old Jan 13, 2005 | 05:40 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Totally!!!
I'm at approx. 370RWHP & I've gotten 119.30mph, so I'd expect 121-123mph though...
Ron
Old Jan 13, 2005 | 06:50 PM
HIGH_INTREST's Avatar
HIGH_INTREST
St. Jude Donor '08
I have 400RWHP 99 FRC 3.90 gear 6spd and ran 11.50 @119 w/1.59 60ft.
150 shot coming next week and looking to see 10.50.
Old Jan 14, 2005 | 02:18 AM
KamPow3r's Avatar
KamPow3r
What about if your in SoCal. I go to LACR in Palmdale and the track there sucks and the elevation is high! I know it can make a significant difference. Has anybody on the boards run there car there and if so what numbers did you run with the mods you got?
-Kam
Old Jan 17, 2005 | 01:45 PM
robz's Avatar
robz
Low 11's are possible in good weather and good driver!
Old Jan 17, 2005 | 02:41 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Mid 11's
-Kam
12.6
Old Jan 17, 2005 | 03:38 PM
KapUSMC's Avatar
KapUSMC
hahaa... I like the 12.6 Al. Yea, I guess alot depends on where the track is, what da is, what track prep is like, and how well you can drive. DR's is also vague... Are they ET Streets, BFG, or Nittos. ET Streets are probably good for .2 on your 60ft. On BFG's with a similar setup, except stock gears and clutch with a 1500 da I went 12.0 in mine. I would expect you should be somewhere in the mid 11's.
To 1/4 expectations?
