Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Stock Manifolds
Old Jan 22, 2005 | 04:18 PM
1320dance's Avatar
1320dance
Default Stock Manifolds
i'm addin a 2800 stall & 224 comp cam. will the cam make lg tubes a must. any other stock manifold cars running low 12's .
Old Jan 22, 2005 | 06:02 PM
LS1LT1's Avatar
LS1LT1
On the right tires you can run low 12s through stock manifolds all day long in any weather (near sea level that is) with a converter and cam. Long tubes are not a must but yes a good long tube header will definitely give you some nice gains.
Look at the QTP Tri Y long tubes. www.quicktimeperformance.com
Old Jan 22, 2005 | 06:05 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
its not a must, but LT headers will help out the cam's SOTP
To Stock Manifolds
