Photography The section to share and discuss photos you took and talk about camera gear.
On Hold
Old Dec 30, 2022 | 07:09 PM
Thomas's Avatar
Thomas
Originally Posted by TwoSmoke
That's interesting.
I don't understand though. Lol
The camera is making the difference?
Dummy me thought a 800 lens would be the same on either body.
You are correct. An 800 is 800 on ANY and EVERY body. Technically you're not getting another inch of reach although that's kind of the adopted terminology. Rick explained it well but I'll have another go at it from a different perspective.
Your lens is pointed at a subject. That subject is projected on to the sensor - which for illustration purposes we'll say is the size of a sheet of typing paper. On a crop sensor ALL the same things are happening only the sheet of typing paper (sensor) is the size of a Post-it Note so the image LOOKS bigger. (the bird closer)
Regarding the R5 in crop mode vs the R7. Rick is correct in his explanation and I'll add a small bit. The following is ultra-mega geek stuff. There is a difference in pixel density between the two cameras. The R7's is greater which means the pixels are smaller and crammed on to a smaller sensor. This is one of the reasons for the significant drop in resolution when you put the R5 in crop mode.
Old Jan 5, 2023 | 08:26 PM
Thomas's Avatar
Thomas
R7.
Old Jan 9, 2023 | 10:44 AM
TwoSmoke's Avatar
TwoSmoke
That's kinda cheating.
Is it even possible to take a bad picture of an eagle?
Old Jan 9, 2023 | 02:43 PM
Thomas's Avatar
Thomas
It is. Believe me.
