Help with new issue
Brightness Value: 5.556
Color Space: sRGB
Components Configuration: 1, 2, 3, 0
CompositeImage: 0
Compressed Bits Per Pixel: 5
Contrast: Normal
Custom Rendered: Normal process
Date Time Digitized: Jul 2, 2024 at 12:55:09 PM
Date Time Original: Jul 2, 2024 at 12:55:09 PM
Digital Zoom Ratio: 1
Exif Version: 2.3.2
Exposure Bias Value: 0
Exposure Mode: Manual exposure
Exposure Program: Manual
Exposure Time: 1/2500
File Source: DSC
Flash: Off, did not fire
FlashPix Version: 1.0
FNumber: 6.3
Focal Length: 600
Focal Length In 35mm Film: 600
Photographic Sensitivity (ISO): 6,400
Lens Model: FE 200-600mm F5.6-6.3 G OSS
Lens Specification: 200, 600, 5.6, 6.3
Light Source: unknown
Max Aperture Value: 5.312
Metering Mode: Pattern
Time Zone for Modification Date: -05:00
Time Zone for Digitized Date: -05:00
Time Zone for Original Date: -05:00
Pixel X Dimension: 8,640
Pixel Y Dimension: 5,760
RecommendedExposureIndex: 6,400
Saturation: Normal
Scene Capture Type: Standard
Scene Type: A directly photographed image
Sensitivity Type: Recommended exposure index (REI)
Sharpness: Normal
Sub-second Time: 186
Sub-second Time Digitized: 186
Sub-second Time Original: 186
White Balance: Auto white balance
Flash Compensation: 0
Image Stabilization: Panning
Lens ID: 65,535
Lens Model: Sony FE 200-600mm F5.6-6.3 OSS
With the 200 - 600 lens you can't get a lower F stop at 600 mm focal length so that's ok. Or adjust your F stop higher to help you balance your exposure along with the shutter speed to get the meter to the correct exposure.
Dan
