how have i missed this thread? that is quite the project you are undertaking and very impressive.. i also see you're in Atlanta, right in my backyard almost! would love to see this project depending on where you actually are.
Originally Posted by eatmydst1234
(Post 1587773722)
You are welcome to stop by...However-there is a $10 cover charge!!! Just shoot me an email richard454 at comcast dot net I'm in Brookhaven- near Oglethorpe University. Richard |
I started reading this from the beginning and then could not stop thinking the thread would stop at a finished swap with video/audio. I was rewarded with frustration as it is still a work in progress. Now I know how YOU feel! OK this is way better entertainment that any TV series, want the next installment yesterday. Way cool and beyond my skills, awesome work, hope you never have to sell it as that is from the heart, it would be like parting with your left lugnut.
Originally Posted by Vitaminmopar
(Post 1587823469)
I'm still at it!! I am headed up to Corvette Expo in Sevierville,TN this weekend with my 73- and maybe pick up some parts. I got my gas tank mounted- looking at the bracket- it didn't seem that tough to flip it over and drop it about 3 inches down. It gave me the extra clearance for lines/vent so I did it. Just had to make up a second bracket to secure the tank- along w/ the stock straps. I made a plastic what looks like a "dog lampshade collar" to go between the deck and the rubber neck filler- to keep water running out the drain line. https://farm6.staticflickr.com/5570/...90ba9562_h.jpgDSCN4718 by richardhayes454, on Flickr https://farm4.staticflickr.com/3926/...63b17f4e_h.jpgDSCN4805 by richardhayes454, on Flickr https://farm4.staticflickr.com/3909/...798e1ccf_h.jpgDSCN4799 by richardhayes454, on Flickr Next big step was to Lizard Skin the interior. I completely coated the cabin- in hopes to keep the heat out. I made an access panel for the engine management -running through the center of the firewall- to help hide the wires. Used a BMW grommet to run the wires through. I also figured out where to relocate the fuse box- since the "Astro Vents" are no longer going to function- running Vintage Air- I'll mount the fusebox in the kickpanel vent location-run the wires inside the fender to hide as well. I will also have my extra fuse /relays mounted in the jack storage compartment. https://farm4.staticflickr.com/3938/...6d8ec506_h.jpgDSCN4826 by richardhayes454, on Flickr https://farm4.staticflickr.com/3933/...d39e18df_h.jpgDSCN4827 by richardhayes454, on Flickr https://farm4.staticflickr.com/3928/...9ae60994_h.jpgDSCN4831 by richardhayes454, on Flickr https://farm6.staticflickr.com/5615/...48f2fe34_h.jpgDSCN4832 by richardhayes454, on Flickr Just a test fit- I need to 'clean up" the box.... https://farm4.staticflickr.com/3940/...35080320_h.jpgDSCN4840 by richardhayes454, on Flickr https://farm6.staticflickr.com/5606/...97a6094b_h.jpgDSCN4841 by richardhayes454, on Flickr https://farm6.staticflickr.com/5615/...92576a60_h.jpgDSCN4845 by richardhayes454, on Flickr https://farm6.staticflickr.com/5614/...314a8d0c_h.jpgDSCN4844 by richardhayes454, on Flickr https://farm4.staticflickr.com/3945/...e54603c3_h.jpgDSCN4833 by richardhayes454, on Flickr And here's a couple of good shots of the engine and car... https://farm3.staticflickr.com/2945/...85c03121_h.jpgDSCN4784 by richardhayes454, on Flickr https://farm3.staticflickr.com/2945/...a9bc410e_h.jpgDSCN4811 by richardhayes454, on Flickr https://farm6.staticflickr.com/5598/...377d247e_h.jpgDSCN4814 by richardhayes454, on Flickr |
It's ALIVE!!!!
OK- Big milestone...
After messing for several days (well maybe a week...) to get the crank and cam sensors to sync...and some software bugs worked out... She lite off!!! Well- I sort of cheated by priming the Throttle bodies w/ gas in a spray bottle- But I have correct ignition.:rock: Next I've got to work the fuel tables- since it looks like I am not getting enough fuel to run. Here's the trigger log-If you only knew what it took to get it to look like this!!! https://farm8.staticflickr.com/7369/...d1a8007d_b.jpgtoothlogger012515 by richardhayes454, on Flickr Here's the cam and the crank sensor- nice straight red line- means there are no errors in syncing the two sensors!!! https://farm8.staticflickr.com/7318/...8a68fcc5_b.jpgcomposite012515 by richardhayes454, on Flickr Here's a quick Video- I mean really quick - but success non the less... all 12 firing... |
Well done, Richard:thumbs:
:cheers: Pete |
WOW! I'm still freaking out over the precision 2x4 supports :willy:. How did you ever get to sleep after hearing it fire for the first time, sound was brief but awesome. Nice.
Thanks Pete!!!
(Post 1588823858)
Found this a WHILE BACK- http://www.airshippictures.com/camar...nds_detail.jpg Pretty secure compared to this- http://digitalcartography.com/n0eq/a...rJackStand.jpg ok it's a Mustang!!!! http://www.bimmerfest.com/forums/att...hmentid=228546 |
Quick Update...
My laptop keeps going on/off line while I am cranking ... so I can get any log info. Tomorrow I'm going to try my GF's laptop...then if all else fails -take my desktop I'm just using for TV internet- and drag it down here to the basement... It's trying...:thumbs: Without further ado- |
Originally Posted by TheSkunkWorks
(Post 1588849341)
This thread is so cool ! Great experience, should be a blast to drive !
You guys are sitting back eating popcorn???
A little progress.... First I tried another laptop...to no avail- keep disconnecting w/ ECU when I would crank it... I did some test files and sent them to Brian @ EFI Analytics, Inc(Tuner Studio Software) He thought having my LS coils not mounted to metal- chassis grounded- might cause some problems w/ the Laptop- He had the same issue. Well- I grounded all 12 and it WORKED!!!...then found out the ECU has a SD card on board and can log w/o being connected to a Laptop... So now I am looking at all these lines on a graph and figure out what I need to do!!! https://farm8.staticflickr.com/7379/...130a6663_b.jpgdata logging by richardhayes454, on Flickr |
I'm always good with outside the box. I think its a cool swap. Not a common swap, however I enjoy the engineering of new concepts in custom car building. I think a Chevy in a BMW would be more common. You may have a following and may an op to build/sell install kits. I have never been a purest and enjoy come custom work. I also glad that the purest are out there preseving the C3.
Would be cool to hear what a V12 would sound like exhausting though side pipes. |
What is the difference in those numbers between AFR and AFR load? Should more than one sensor be showing AFR?
Originally Posted by Richard454
(Post 1588879605)
I always get the munchies for popcorn when I sense that I'm about to be well entertained. :D |
Popcorn for everyone!!!:lurk:
It's running..... After checking EVERYTHING...and I mean everything...Recalibrating..Changing the start-up tune- numerous times- It was the fuel pressure regulator...I put some vise grip in the return line and she started right up. So the regulator was just letting the fuel run back to the tank- not enough pressure for the injectors!!! Have the O2 sensor disconnected - and haven't done ANY tuning-or after start enrichment- no exhaust- but here's the video- Here's a little revving- |
Great to hear it running. Sounds like a warbird. :thumbs:
Congratulations!
Way Cool :cheers: |
It's the longest thread I have ever followed and all I can say is, "WICKED". Great job and congratulations, keep us posted: :woohoo::cheers:
