At 1,000 rpm and no load (in neutral/clutch disengaged), I would expect ~10 gm/sec flow rate for warm/hot coolant temperature. So you can adjust your maf to read ~10 gm/sec at 1,000 rpm in ALDL mode and monitor the BLM behavior once in closed loop. Use the BLM as your rich/lean indicator.
If the BLM is too rich or too lean (and if you trust everything else to be correct, a big if), you can adjust the MAF or fuel pressure as a crude method to compensate for the mixture error, or you can tune it properly by re-programming the eprom accordingly. |
This is great information. Thank you
Originally Posted by Nomake Wan
(Post 1601638243)
As a result, if you remove the MAF, the ECM has no way of measuring airflow whatsoever and will shut the engine off immediately.
I am a man with a failed MAF that is disconnected and waiting for me to bite the bullet and install the EBL. Car runs great, plug MAF in, it stumbles, coughs, and dies erratically. Un plug the MAF anf go have a happy drive. Gets lean up top though so no racing, but cruises just fine. |
Thank you. for the advice.
So you are installing the Dynamic EFI EBL. Something I am really considering. |
Originally Posted by KyleF
(Post 1601761487)
No it doesn't.... It has a back up mode that runs off set tables
