[PIC] Installed a Lokar Throttle Cable
How difficult is that to install?
Looks good, gotta get one of those. Thanks for posting. It may be the picture angle, but it appears that you only have one spring installed. It should be a double spring, they are wound differently...a safety device.
so nice... :D looking good :thumbs:
Have a part number?
Is that bracket included? |
Very nice :thumbs: A quality product :thumbs:
Originally Posted by Jughead
Have a part number?
Is that bracket included? The part number is TC-1000HT The bracket is not included.. I actually got my bracket with the transmission because it also has the bracket for the TV cable.. |
Originally Posted by GrandSportC3
I have the second spring.. The gas pedal resistence is too high with the second spring...
Carefully streatch them a little to loosen the resistence or change the mount location. You need both, PLEASE put the second spring on.
Here we go again! Olivier, that's a safety item. I KNOW you are safety minded. You don't want to be sitting in that seat if the trottle sticks open because the one spring broke. I've seen it written up in some tech requirements. You might not pass of they look for it. I re-routed my springs. Bought a Mr. Gasket throttle spring stand-off that attaches to an intake manifold bolt. Just enough pressure to keep my lead foot off the floor on the highway. :yesnod: |
Carefully stretch them a little to loosen the resistance or change the mount location. You need both, PLEASE put the second spring on.
Oliver whats the deal with the TV cable, does it need to be pulled out like this for the transbrake? If so your going to be running full line pressure all the time. Wouldn't be too good to run on the street unless you plan on freshening it up every few months. |
I understand that but why is the TV cable pulled so far out
I'm running a hydraulic and not electric transbrake... It works completely different than a regular transbrake.. Regular transbrakes usually require a fully manual valvebody.. Mine is a automatic valvebody which is great for bracket racing... I want this car to be dead consistent...
Ok I just reread your post, no I don't understand this, How do you engage and release the transbrake if it doesn't have an elec solenoid to hold the line pressure |
Looks good!
I got the black cable, I wish I had the braided one... |
The transbrake basically takes the spot of gear number one. Well - the gear is still there but when you put the shifter in "1" you are actually on the transbrake.. You can shift into 2 which will activate the transbrake which will launch in first gear and the 1-2 shift will be automatic and the 2 - 3 shift manual... The transmission and converter are dialed in to my cam and should be shifting at the correct RPM. At least I hope so.. If it won't work as planned, I'll go with the manual valvebody. |
Originally Posted by 427V8
Looks good!
nope - it doesn't have a solenoid...
The transbrake basically takes the spot of gear number one. Well - the gear is still there but when you put the shifter in "1" you are actually on the transbrake.. You can shift into 2 which will activate the transbrake which will launch in first gear and the 1-2 shift will be automatic and the 2 - 3 shift manual... The transmission and converter are dialed in to my cam and should be shifting at the correct RPM. At least I hope so.. If it won't work as planned, I'll go with the manual valvebody. But why is the TV cable pulled so far out? Does it have to be this way to keep enough line pressure for the transbrake? |
