Does this look right?
The compression ratio is where I would expect it to be, if that's your question.
Its a 355 with 4.035 bore. Seems like to much horsepower to me. Its at the flywheel btw.
It's a big cam, but what heads were used in the sim? With good heads, those numbers are possible. BTW, what analyzer program is that?
That's engine analyzer, what heads are you using ? intake, carb etc. ?
Here's mine, everything is optimal, open headers etc. :D http://img.photobucket.com/albums/v1...neAnalyzer.jpg |
Im using L-98 heads with a very good port job, Victor intake, and 650 cfm carb.
Those numbers are in the ballpark, put it on a chassis dyno if those numbers are correct I would expect to see way over 300 HP maybe near 350 HP at the rear wheels :D
You sure you really have a zero deck height? And you going to use a steel shim gasket on an aluminum head? :nono: |
Originally Posted by yellow73sb
It is zero decked. I thought we had a .043 gasket but my dad said .028. My uncle uses a steel shim on his car BB. Its a 600 ci thats makes 1300 hp. :eek:
http://www.gmpartsdirect.com/perform...CATID=697.html I'd be interested on what you did to port the L-98 heads. I'd like to try and port mine but i'm afraid i'm gonna screw them up. |
yep the composition gaskets are made very thin now days. There are a couple of .028 for aluminum. Note the corvette gasket is .051 :eek: I've been wondering why i don't have much compression.
