14 months of storage
What would 14 months of storage would do to my ride? Besides 4 flat tires unless I put it on stands...
This has been a topic of much discussion. Search for threads related to 'storage' or 'storing' and you'll get a bunch of info.
A few key points: -Overpressurize the tires by 5# and park on styrofoam. No jackstands needed. No harm done either way. -Change the oil & filter -Fill up with high grade gas and stabilizer like Sea Foam and drive for 50 miles. Top off tank as full as is reasonably possible. -Put a bar of soap in the cabin. -Put a moisture absorber in the cabin. -Cover the vehicle. -Put steel wool in the tailpipes. -Put traps & some poison in the rims of tires. -Buy an electric critter-annoyer from a hardware store and plug in near the vehicle. -Some say to attach a trickle charger to the battery. Some say to remove/disconnect the battery. Some say not to worry either way. Other than that, I'm sure others will chime in and correct me if I'm wrong. |
I think that all of the previous posters suggestions are good ones.
I just got my Vette out after it set 3 years in what is basically a barn. It had a rats nest behind the radio and climate control module that was as big as a softball. I ended up taking the whole dash apart to make sure there was no wiring damage and I was VERY lucky. I think that rat damage to the wiring harness would be the worst possible damage from storage. Using something in the fuel to keep the injectors free is also a big deal. I have had to replace injectors in cars that have been in storage. I would add more than five pounds to the tire pressure. I would air them to the max inflation pressure on the sidewall and maybe even more than that. The max pressure rating is for driving. Have a safe tour and we appreciate your service. Best of luck, |
Great suggestions above. I took one of my vehicles out of storage after three years and had no problems at all. Definitely air up the tires. I would remove the battery completely. I left the battery on an automatic batterry tender and amazingly the battery was okay when I checked it out after 3 years. I pumped out all of the old gas Stabil and all and replaced it with fresh gas before firing it up. I put in fresh premium gas, put the battery back in, turned over the motor a few times with the coil disconnected. Reconnected the coil, hit the starter and it fired right up like I had just parked it overnight. No leaks, no problems at all. Thanks for your service. Have a safe deployment.
