rear 02 sensors on long tube headers
When installing long tube headers, how are the rear 02 sensors installed? Is it passenger side to passenger side and drivers side to drivers side or are they criscrossed.
I'm positive they were criscrossed when I took the H pipe off, but have read that they should go left to left and right to right, or does it really matter. :cheers: |
They are not crossed, they just look that way. :cheers:
Rear O2 Sensors
Just put headers and high flow cats on the rear sensor are crossed. The drivers side wiring goes to the passenger side sensor and the passenger side wire goes to the drivers sensor.
On our 2004 it was:
Front passenger side sensor wire goes to passenger side located front wire plug Front driver side sensor wire goes to driver side located front wire plug Rear passenger side sensor wire goes to driver side located rear wire plug Rear driver side sensor wire goes to passenger side located rear wire plug I just traced wires before i uninstalled anything and marked plugs w/ tape labels saying whihc O2 sensor ran to em. The again, since we have 04 w/ the higher wattage sensors and am running all 4 we didn't have to move/swap positions of any; they all stayed in same position. All is well |
The factory routing of the rear O2 sensors and the attachment of the sensor to the harness at the opposite side of the car may seem odd at first glance, but it's done so that the sensor cable only has to make one right angle turn (rather than a 180 and another 90 to route up the same side.) The fronts don't have this issue and attach as you would expect. Both front and rear however do follow the simplest physical route. |
Originally Posted by ToplessTexan
The only time you need to run left to left and right to right is when you are installing a set of rear sensors to be used as front sensors and so are connecting to the front O2 harness positions. Otherwise, connect them the same way you found them.
It's the rears that are causing all the confusion-the fronts obviously go left to left and right to right-but i guess the rears are crossed according to everyone here.
