MTI Six Shooter shifter owners please enter
I just got done with the install and even though I have never owned any other shifter, it seems very notchy and alot of effort to shift. I was hoping the MTI shifter was smoother than it seems, so my question is did I do something wrong during the install? Any suggestions?
thanks :thumbs: |
It shouldn't be hard to shift. Since the stock shifter has no feel at all, the MTI will have a feel of a more precision pattern and engagement. Some may call this notchiness. My wife had trouble shifting my Hurst but she has no problems with the MTI.
Let's hear more about this shifter. When I first heard about it, it sounded like what a lot of us are looking for. Anybody else use this and another after market shifter?
Thanks, Clayton from Las Vegas :flag: |
I've had this shifter in my '02 Z06 for almost a month now and I REALLY like it. I replaced a Hurst with it. The Hurst with the springs in it was just rather tough to shift, and when I took out the springs, way too sloppy feeling. Here's a pic comparing the MTI on the left with the stock shifter on the right.
http://www.corvetteflorida.com/photo.../shifter01.jpg Unfortunately I didn't get a pic of the MTI compared to the Hurst shifter. I put an "8-ball" style shifter knob on it to keep the height low and it feels just RIGHT for me. http://www.corvetteflorida.com/pics/billiard_knobs.jpg I wrote a bit more in depth about the shifter here -> http://www.corvetteflorida.com/forum...read.php?t=288 If anyone is interested. |
The shifter feels very solid and precise, but it takes more effort through each shift, I just thought it would be more, effortless. Maybe I did something wrong w/ the install? :ack:
hmmmmmmmmm
I have the MTI shifter and it is leaps above the stock.
thanks :thumbs: |
Originally Posted by bandit_99
Rich, where did you get a 2 inch ball instead of the 2 1/4 inch ball? Do you have the part number? Also, how is that in the heat? I have the kirban billet ball- which is awsome for feel and height, but I have to put a cover on it when I park anywhere in the sun or I torch my hand when I get back in the car.
Actually I did have the car parked where the shifter knob was in full sun for an hour or more. It was hot to the touch, of course, but cooled off rather quickly. Not BURNING hot, like I thought it would be, however. Actually the steering wheel felt MUCH hotter to the touch. You may want to consider a white one if that is a real concern for you. White would deflect the heat better then a black one would. I've seen the polished and billet shifter balls and thought they would fry my hand if they got exposed to the sun for any length of time. And yes, the 2 inch ball feels perfect in my hand. I was afraid the slightly larger ball might have felt unwieldy and awkward. |
thanks man. Is your 2 inch one made by hurst?
Thanks :cheers:
I am looking at the MTI for you 02 Z and I have a Momo Italy shift knob already. I am wondering how it will fit seeing that the shift lever has that bump not to far below the threads, and the shift knob has a part that has to screw on over the allignment screws. :confused:
Originally Posted by cenzo
Stacey, the MTI is a reworked stock shifter with a raised pivot point and a shorter shaft. It has to be notchier and require more effort than stock. It ain't your fault. But this too will also pass.:thumbs:
thanks :thumbs: |
I am assuming that if it were, it would have "HURST" imprinted on it, which this one does not. I specifically did NOT want that extra lettering on the shift knob.
Originally Posted by gorillavet
It will fit fine. I used a MOMO and had no problems. That "knob" in the shifter is low.
Not sure where you get reworked stock shifter but the MTI Racing six shooter shifter does have a higher pivot point. It is not notchier nor does it require more effort than stock. Just wonder, do you actually have one or ever shifted one???
"The price for throw reduction is increased effort and reduced smoothness, AKA “notchiness”, and when the required effort becomes too high for a given user, the shifter velocity drops to the point that you’re better off going back to a stock shifter." Chris Reinhart, six shooter designer "I just got done with the install and even though I have never owned any other shifter, it seems very notchy and alot of effort to shift. I was hoping the MTI shifter was smoother than it seems, so my question is did I do something wrong during the install? Any suggestions? thanks " c5z06vette Gorillavet, I have not shifted one. But I believe Mr. Reinhart and I believe Mr. c5z06vette. I also understand the principles of leverage from my see-saw days. But if I ever have to go into battle, I'd want a staunch advocate like you by my side. BTW, what do you suppose MTI does with those core C5 shifters? |
