Car Ramps
What is the difference betwwen the Rhino Ramps and the Race Ramps from the Corvette speciality stores? Now I know the Rhino's are about $60.00 and the Race Ramps are around $185.00. On a stock c5 will the front end scrape when using the Rhino's?
I've got the Rhinos and I only paid like $35 for them at Advance Auto. They work just fine on my 2003 Z (stock suspension).
:thumbs: |
I have Rhino ramps and the front air dam scrapes and has been torn off using them. that was even after I first drove onto a plank of 2x12.
The car is a Z51 at stock height. I know only back onto the ramps and jack up the front. |
The car is a Z51 at stock height. I know only back onto the ramps and jack up the front. The race ramps were previewed here and the consensus was way too over priced. Do a search, you can build ramps out of wood for a lot less, even less than the $60 you quoted for Rhino. I paid like $35 for mine at Pep Boys, but its your $$$, spend it however you wish. |
Originally Posted by Silver98
I don't understand that. I have a stock height 98 and the ramps work just fine. The front air dam swings up, but the ramps are only the width of the stock tires. I don't even need a 2x12 to drive onto first.
Originally Posted by Zuti
:iagree: Never had an air-dam problem with the Rhinos. The air dam is very flexible.
i have rhino ramps.i use a couple of cut 2x4 pieces of wood just in front of the ramp and no problems yet.the 2x4 raises the front just enough......:thumbs:
