Drill/Tap Specifications for Clutch Mount Boss on Block
I am planning to install a different engine Block in my car. The clutch mount boss on the block does not have the hole drilled to mount the clutch bellcrank ball stud. Is there anywhere I can get the specifications on depth to tap etc.. I have looked at some other blocks and some of the holes are off center , does this have any effect on the operation of the cluch Z bar? The Block is a Bowtie 10051107, I am assuming that all 66 Corvette Big Block components will mount correctly. Any help is greatly appreciated, Thanks
If you can find someone to drill and tap the outside of an iron block; let me know who/where.
There is a Z bar conversion piece that bolts up. :thumbs: http://www.sdpc2000.com/catalog/1006...l-Brackets.htm |
Edit:
Refer to post below. Wrong hole, that's one of the oil cooler/plug holes. I see the correct hole but there is no reference dimensions. You could scale the drawing but that would be a crap shoot. |
Originally Posted by 67L36Driver
(Post 1558655125)
A medium to large radial arm drill press should get the job done. Carefull setup is the key to success.
An old Chevy Power catalog I have shows the hole 2.52" forward of the crankcase/bellhousing face and 2.36" above the pan rail. For the thread, just measure the stud. Check the tap drill depth on any SB or BB with a dial caliper. Keep the drill depth to a min. and use a bottoming tap.:thumbs: |
The Z-Bar ball stud has a 1/2"-13 thread; on original blocks, the tap drill hole is 0.86" deep, tap depth is 0.70". :thumbs:
Thank you for the technical detail. I have been on the internet all day trying to find this information. My next step was to call GM.
Originally Posted by knight37128
(Post 1558654260)
http://i53.photobucket.com/albums/g6...funny/gif3.gif |
Originally Posted by buns
(Post 1558666659)
I'm confused by this statement/question. It sounds like you are suggesting that drilling and tapping a cast iron block is difficult.
New cast iron is not difficult. Old cast iron will crack. Most of the outfits (that I have seen) heat it in an oven before any work is done to cast iron. |
Originally Posted by c66vet
(Post 1558663665)
(Post 1558669104)
Bingo. :yesnod:
