Where can I buy 1.8 Roller Rocker Kit for C6
I am wanting to upgrade the Rocker Arms in my 2006 C6. I have found the SLP Rocker Arm Kit but they are not Roller Rockers. Where can I find 1.8 Roller Rockers for my C6. I am wanting to buy them as a kit if possible just like the SLP Package. If not I can buy the individual pieces I want to make sure they are all compatible.
Also does anyone have any thoughts on this upgrade and what are the differences between the SLP type vs the Roller Rockers? |
Originally Posted by rjung
(Post 1558810056)
Also does anyone have any thoughts on this upgrade and what are the differences between the SLP type vs the Roller Rockers? http://www.motorsporttech.com/c6_engine01.asp Jesel Roller Rockers Jesel's shaft mounted rocker arms are some of the best money can buy. Longer rocker arms provide higher rocker ratios, proper travel, arc geometry and enough rocker-to-valve spring clearance to run big race springs. CNC-machined aluminum rockers are extra rigid to insure true rocker ratio. Shaft mounting reduces reciprocating mass for high rpm use, easier access to valve springs, lash caps, retainers and locks, longer valve spring life and is a complete bolt-on assembly with rocker arms, shafts, stands and hardware. Note: Clearancing of the factory valve covers is required with the use of these rocker arms. Description Price Jesel SS Series 1.7 Roller Rockers (non-adjustable) $745.00 Jesel 1.7 Roller Rockers (adjustable) $1399.00 Jesel 1.8 Roller Rockers (adjustable) $1399.00 |
