Lifter noise with only 22k?
Hi everyone, I thought I'd put this question out to your collective experience before I start yanking my motor apart. I own a 91 Coupe (L98 motor). Starting the car, no noise. Regular driving, no noise. Stretching each gear out a little I get a wicked valve tap at 3000 rpm and up. But the car only has 22k on it! Could it be a clogged pushrod not bringing oil where it should go? Can a lifter give up with that few miles? If I pull the valve covers off, can I get to the lifters to replace them? Last question...can you "see" a bad lifter or is it all internal damage that creates the noise? Your input would be greatly appreciated. I'm all ears :bigears
I'ld try some hope-in-a-can before ripping and tearing. Run it with a Seafoam-like product in the crankcase then oil change w/ Mobile 1.
Others will certainly disagree. |
Originally Posted by Tralfaz
(Post 1559788255)
Wonder if you are hearing a loud injector? Just a thought... :)
Sometimes the lifters can get varnished up and stick, especially if it sits a lot. The miracle in a can thing outside of pulling a valve cover to check for something obvious may be a place to start. Personally Id try a mechanics stethescope (if youre lazy use a long screwdriver) to try and determine exactly where the noise is coming from first.
You could also have a cat converter going bad. The converter will only make noise when it gets hot, but will do it all the time once it does.
thanks for the tips, I've already dumped a can of Marvel Mystery Oil in it with a fresh oil change. It hasn't helped much. I guess I'll pull the valve covers off next and look for the guilty party. Might not be a bad time to throw some 1.6 roller rockers in, right?:thumbs:
ttt :rofl:
