Can you splice fiber optics?
For some reason Bubba cut the fiber optics for the front of my '70 by the dimmer switch. I hate to be lazy, but can I simply splice the cables with heat shrink (or some other trick) instead of re-running an entire new cable?
:cheers: |
There are splice kits available, but you can do it with a razor blade and heat shrink. Make a very sharp square cut and but the ends together.
You just have to make sure the ends are bound up well, then make very square cuts. I would think that there is some kind of clear epoxy that would be used to make sure the light transfers well. I don't know that heat-shrink tubing would hold well enough, given the harsh environment. If it were me, I'd do an internet search for a splice kit.
seems like I remember someone talking about a repair kit they got from radioshack at one time... good luck
i wouldn't use any epoxy on the ends of the cables. the optical density of the epoxy might simply reflect the light back into the cable. as posted above, make a square cut with a razor blade and butt the two ends together. i'd use a short piece of wire and super glue it to the plastic case of the cable to hold the two ends tightly together, test it, and then heat shrink a wire wrap over it.
jeff |
Originally Posted by Ray Y
(Post 1563567726)
:cheers: Can't you just buy a new fiber line? Sorry to be to blunt, but it may not work. It all depends on how much forgivness you can get away with. :cheers: |
The fiber cables just transfer the light from the bulbs to the console. A butt splice will work. You can use 1/8" compression fittings. Just make sure the ends are cut square as stated above.
Originally Posted by c69vete
(Post 1563572059)
:cheers: |
I did my senior project in collage on fiber optics and the effects of splicing. Keep in mind that this is not data we are talking about here so all you need is a good cut on both sides and the ability to keep them as close as possible to each other when making the splice. Another thing I learned when working on my project is that just cutting the fiber is not enough (at least for data) and to clean up the data loss (light loss and scatter) I found that taking a piece of 1000 grit or higher sand paper and polishing the ends in a figure 8 pattern gave the best splice performance. As far as cutting the fiber with a razor blade it is probally OK in this application but we use special one time cutters at work that make a perfect 90 degree cut. I think the shrink wrap method would work good.
Along time ago we use to use a special jig that would cut the cables and polish up the end before we would splice it together. Now with the newer style basic just cut the fiber and we put what looks like a buttjoint splice connector on them works good for our high speed data collection. Radio shack does still make a kit and MAD (Mid America) has one also. Good luck.:thumbs:
wro87 |
Originally Posted by wombvette
(Post 1563567915)
Any fiber optic repair/ splice works poorly at best. IMO
Get a sub-harness |
Originally Posted by theandies
(Post 1563572339)
Thats funny. Its going to be hard to put that figure 8 on the end of that little fiber cable. Hey folks, its just a light we are talking about here. A butt splice will work fine. |
(Post 1563577959)
(Post 1563577959)
Hey folks, its just a light we are talking about here. A butt splice will work fine. It's not hard. Place your sand paper on your workbench. Hold fiber optics in hand, place cut end of fiber onto sand paper keeping the end parallel as possible to the sand paper. Now all you have to do is move the fiber optic in a figure 8 pattern a few times. Believe me this works good and increases the light transfer through the splice. |
How about just buying a new one, are they that expensive that you need to work on something the size of a piece or hair?
:cheers: |
As a worst-case scenario, you could always wire a small 12 volt bulb in parallel with the lamp being monitored and let that shine by your cut fiber end. Maybe a "Bubba" (or ingenious depending on your POV), but this would solve your problem and provide the brightest fiber optic at the termination point.
The fiber optics all worked on my '70, but they were never all that bright and the various monitor point lenses had different intensity depending on whether they were on the straight path or angled path lens. |
Thanks for the input guys!
I'm going to try splicing and if that doesn't cut it then I will go for a harness replacement. In a good year in my part of the world I have til mid-May to wrap everything up before Winter is dead and the roads are clean, and right now a new firewall insulation pad is my gating constraint...backordered til near the end of January. A data quality type of connection is an interesting alternative. I have access to mini-lenses and sealing ends at work. Might try a lens to lens butt splice in a sealed connector just for grins since it doesn't need to be data quality connection, and looking at the factory ends it's better than what was available in 1970. Thanks again guys. I hope your Winter is going great wherever you live! :cheers: |
Originally Posted by jnb5101
(Post 1563571527)
jeff Good Advice. |
