How to Keep T-Top Weatherstrip From Sticking?
Well I'm fairly new to Vette ownership but noticed when I took the T-tops off the weatherstripping really wanted to cling to the car. I was thinking there's gotta be somehting you could coat this with so releases easy. Well - anybody have something they recommend that's proven to work?
My Step Dad used to clean all the weather stripping with a rubber treatment of some kind when he had sticking problems. I have never personally had the problem so I don't know how much more help I can be.
Was this the first time you have removed the tops or does it do this every time you remove the tops? It could be they haven't been off for a long time and that caused the rubber to stick to the car. I treat the weatherstripping on all of my cars with Meguire's rubber and vinyl protectant. Actually, it's the only stuff I'll detail the inside of my cars with.
This is first time I removed them - the previous owner had new T-tops put on and likely have been on their for a couple years w/o being removed. Maybe it won't be an issue next time but I'll try the Megires which can only help. Thanks.
I use a marine grade protectant called 303. You might have to visit a boat place to find it or get it on the web. I've been using it on rubber weatherstrip, vinyl trim, tires, etc for years. Doesn't produce the glossy shine some of the other protectants do but that's one of the reasons I prefer it.
I also know a guy that uses silicone spray lube for his weatherstrip. Seems to work well. DC |
Vader vette
Yep DC 3 said it all, A Hottub cover also uses the protectent 303 any good hottub place or @sonshine covers has it ask for Donna.
One of my stints since leaving the corporate world was an 18-month period in service at a GM Pontiac-Buick-GMC dealership. In winter people would have their cars washed at -20*F and then find that the metal on their doors was frozen to the weatherstripping. This led to some frustration as you can imagine.
The solution was simple and inexpensive. GM/Delco sells a silicone emulsion for weatherstripping. It repels water and prevents rubber rot. So the ice would not form on the rubber. I have just treated all the rubber on my 1974 convertible; not for ice but for rot. It will serve your t-top purposes as well. http://img.photobucket.com/albums/v1...ilicone001.jpg |
Originally Posted by paul67
(Post 1565134169)
I agree silicone is effective.
I once had an extremely knowledgeable and experienced Vette guy tell me to use a light coating of clean brake fluid for sticking T-Tops. never tried it but was kinda surprised at the suggestion. Smile on |
Originally Posted by Wuttin
(Post 1565145866)
Very bad idea. Use a silicone product or a polymer polish like Nu-Vinyl to put on your weatherstrips. That also will protect them from drying out.
Brake fluid? Keep it away from paint, vinyl, rubber, etc. Anything you do not plan to dissolve and replace. Where do these bizarre ideas come from?
Once very three months I spray all my w/s on the car with a 100% silcone spray. DO NOT use anything other than silicone, it will eat the rubber up bad.
I have all NOS w/s on my car, and this treatment keeps them soft and prevents sticking. |
silicone and nothing else period.............
Silicone grease
Found out about this in my 96 Corvette's owner manual. Apply to weatherstripping Delco Remy 1974984 1 D#1920 Silicone Dielectric Grease . Come is a small plastic tube and is clear.
Most auto part stores carry an aerosol brand of spray silicone to spray on as a lubricant on doors, locks, wires etc. Cleanest way would be to spray some on a clean shop rag and wipe down the rubber surface. I used to see it in alot of hardware type stores or like Bennys Auto, called it Alumalube but it was just silicone for lubiing Aluminum Strom windows.
Bill in RI |
(Post 1565154886)
(Post 1565178421)
I kid you not...this was suggested from an old school strip racer who's been around vettes for the better parts of 40 years. He currently owns two C1's that he completely resto'd to Bloomington Gold status. Also owns a 66 that's underway (used to be his race car). I had owned my '79 for all of a week and mentioned the sticking of the T-Tops and this is what I was told. There may have been a time when this was the best/only option, but who am I to judge. I just let common sense prevail and used silicone instead...
I won't get into bringing lacquer thinner near painted surfaces. That is a story for another day. |
(Post 1565178421)
Bill in RI |
I got some stuff in a tube at a Napa Store. It's called Sil-Glide, blue and yellow tube. This stuff is great. Highly recomend it for t-tops...
Just a suggestion>>>DON'T EVER GET ANY KIND OF BRAKE FLUID NEAR YOUR PAINT. <<<< Dave |
