95' M/C Question
Anyone happen to know the O'Ring size of the one's for the Brake Master Cylinder Resvoir?
I want to get them in advance. Thanx |
That's an easy one. There are no "O" rings from the brake lines into the MC. The seal is metel to metel compression fit, the "bubble" flare on the brake lines is in essence the "O" ring....
http://img166.imageshack.us/img166/6...leflaretp6.jpg "one less thing" :cheers: |
Originally Posted by CAJUN C4
(Post 1566376956)
Anyone happen to know the O'Ring size of the one's for the Brake Master Cylinder Resevoir?
(Post 1566379591)
"Resevoir" 2 ea. O'rings
If you really want to make sure of a good seal, you can use teflon tape. Just be careful not to go 'over' the line tip - it will interfere with fluid flow. You put an O-ring in that orifice where the tip goes, it's gonna' leak. |
Originally Posted by schrade
(Post 1566380340)
Not sure what you're sayin', or askin', but like Mr. Mike said, there is no O-ring on the end of that line fitting.
If you really want to make sure of a good seal, you can use teflon tape. Just be careful not to go 'over' the line tip - it will interfere with fluid flow. You put an O-ring in that orifice where the tip goes, it's gonna' leak. Gonna flush the Hydraulic Brake Syestem and will Drain the Resevoir prior to doing this.I was going to buy new O'rings in advance...That's all |
