95' M/C Question
Old Jul 20, 2008 | 08:44 AM
CAJUN C4's Avatar
CAJUN C4
Default 95' M/C Question
Anyone happen to know the O'Ring size of the one's for the Brake Master Cylinder Resvoir?
I want to get them in advance.
Thanx
Old Jul 20, 2008 | 10:54 AM
MikeC4's Avatar
MikeC4
That's an easy one. There are no "O" rings from the brake lines into the MC. The seal is metel to metel compression fit, the "bubble" flare on the brake lines is in essence the "O" ring....
"one less thing"
Old Jul 20, 2008 | 01:27 PM
CAJUN C4's Avatar
CAJUN C4
Originally Posted by CAJUN C4
Anyone happen to know the O'Ring size of the one's for the Brake Master Cylinder Resevoir?
Thanx
"Resevoir" 2 ea. O'rings
Old Jul 20, 2008 | 02:51 PM
schrade's Avatar
schrade
Not sure what you're sayin', or askin', but like Mr. Mike said, there is no O-ring on the end of that line fitting.
If you really want to make sure of a good seal, you can use teflon tape. Just be careful not to go 'over' the line tip - it will interfere with fluid flow.
You put an O-ring in that orifice where the tip goes, it's gonna' leak.
Old Jul 20, 2008 | 04:12 PM
CAJUN C4's Avatar
CAJUN C4
There are 2 O'Rings sealing the Resevoir to the Body. No big deal I'll just match em up.
Gonna flush the Hydraulic Brake Syestem and will Drain the Resevoir prior to doing this.I was going to buy new O'rings in advance...That's all
To 95' M/C Question
