Carb filter spring
70 vert, 350, Rochester carb. I am missing the spring that goes into the carb before the inline fuel filter. Anyone have a picture of what this looks like and where I might be able to get one ? Thanks
It is a small coil about 1" dia. and 2" long. Can be purchased at any local auto parts store,
Advance is where I got mine. |
NPD and Classic Industries also carry these and the filters and the gasket/seal as well.
Originally Posted by Reggie Dunlop
(Post 1567825426)
Originally Posted by My70
(Post 1568349217)
Does the spring get used with the paper fuel filter as well as the brass fuel filter?
Here you go My70,
Summit Racing Filter PN= ACF-GF427 Spring PN= HLy-162-500. Note the springs is what you want. Check out this thread a few months ago.:thumbs: http://forums.corvetteforum.com/c3-t...er-spring.html This should help you out.:cheers: |
Originally Posted by GPGG70
(Post 1568352681)
Here you go My70,
You got it. Insert the spring, then the filter with the open end last in. Think of how it works. Gas comes in the center of the filter, then through the walls and out to the carb. The spring holds the filter so that it seals around the open end. If the filter becomes plugged, the spring is pushed back by pressure and fuel continues to flow so at least the engine will not stall.
