SOLD- 2004- Machine Silver Coupe -With GM Warranty
2004 Coupe, Auto, 3:15, 1SB Package, 6 Disk Changer, HUD, Dual Tops, Loyds Etc. 15,4xx miles. Clean Car Fax (for what That is worth:rolleyes:).
I am the first titled owner of the car, kept in my garage. I will post some pictures later. Stock, No modifications to car except added Sound proofing (12-15 lbs worth) to dampen road noise. Mileage is from occasional too and from work (105 miles round trip) all interstate. Never tracked, raced, HPDE etc. Never Smoked in. Work done on car: TSB performed on leaking rear end (Common C5 issue) and has not leaked since it was done TSB on fuel sending unit (gas gage read empty) repaired and no problems. Added: *MP3 input for MP3 player (in place of 6 disc changer) *GM Bra (for love bug season in Texas) *Optima Red Top battery. *2nd top is in a protective case *Aluminum gas and dead pedal Original floor mats if you want them too! :lol: Major Guard is good until 6-13-11 or 41500 miles. $100.00 deductible $25,500 with GM Major Guard Protection plan warranty. Wife says I only need 1 Corvette, Here is my effort to sell it.:( (Kids are mad because they like the pop up headlights) Not in a hurry to see it go, but I said I would post it. So..... More information added VIN # 1G1YY22G045129794 VEHICLE BUILD INFORMATION Merchandising Model : 1YY07 -2004 CORVETTE COUPE Gross Vehicle Weight Rating : 1682 kg (3709 lb) Order Number : HFFKNV Build Date : 05/11/2004 Build Plant : 145Y OPTION CODES AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE C2L - ROOF PACKAGE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - 50-STATE EMISSIONS G90 - REAR AXLE-3.15 RATIO G92 - AXLE: 3.15 PERFORMANCE RATIO IL3 - TRIM INTERIOR DESIGN- AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NK4 - LEATHER WRAPPED STEERING WHEEL NT9 - FED EMIS SYS, TIER 2 PHASE-OUT N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN QF5 - HIGH POLISHED ALUMINUM WHEELS SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM U1S - CD 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION VDC - VEHICLE INFORMATION CD VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR 1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN 1SZ - PREFERRED EQUIPMENT SAVINGS 67U - MACHINE SILVER 92I - LT GRAY INTERIOR TRIM 923 - LT GRAY SEATING TRIM http://i109.photobucket.com/albums/n...upeSticker.jpg |
:lurk:
Added additional Information on options and warranty.
Sold for $25K |
