2004- Machine Silver CPE -With GM Warranty
Location: I speak the truth. Harsh but accurate. The Woodlands Texas
1 Post
St. Jude Donor '09-'10
SOLD- 2004- Machine Silver Coupe -With GM Warranty
2004 Coupe, Auto, 3:15, 1SB Package, 6 Disk Changer, HUD, Dual Tops, Loyds Etc. 15,4xx miles. Clean Car Fax (for what That is worth).
I am the first titled owner of the car, kept in my garage. I will post some pictures later. Stock, No modifications to car except added Sound proofing (12-15 lbs worth) to dampen road noise. Mileage is from occasional too and from work (105 miles round trip) all interstate. Never tracked, raced, HPDE etc. Never Smoked in.
Work done on car:
TSB performed on leaking rear end (Common C5 issue) and has not leaked since it was done
TSB on fuel sending unit (gas gage read empty) repaired and no problems.
Added:
*MP3 input for MP3 player (in place of 6 disc changer)
*GM Bra (for love bug season in Texas)
*Optima Red Top battery.
*2nd top is in a protective case
*Aluminum gas and dead pedal
Original floor mats if you want them too!
Major Guard is good until 6-13-11 or 41500 miles. $100.00 deductible
$25,500 with GM Major Guard Protection plan warranty. Wife says I only need 1 Corvette, Here is my effort to sell it. (Kids are mad because they like the pop up headlights) Not in a hurry to see it go, but I said I would post it. So.....
More information added
VIN # 1G1YY22G045129794
VEHICLE BUILD INFORMATION
Merchandising Model : 1YY07 -2004 CORVETTE COUPE
Gross Vehicle Weight Rating : 1682 kg (3709 lb) Order Number : HFFKNV
Build Date : 05/11/2004 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C2L - ROOF PACKAGE
DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE EMISSIONS
G90 - REAR AXLE-3.15 RATIO
G92 - AXLE: 3.15 PERFORMANCE RATIO
IL3 - TRIM INTERIOR DESIGN-
AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QF5 - HIGH POLISHED ALUMINUM WHEELS
SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL
UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U1S - CD 12 DISC CHANGER, REMOTE
U52 - ELECTRONIC INSTRUMENTATION
VDC - VEHICLE INFORMATION CD
VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR
1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
1SZ - PREFERRED EQUIPMENT SAVINGS
67U - MACHINE SILVER
92I - LT GRAY INTERIOR TRIM
923 - LT GRAY SEATING TRIM
Work done on car:
Added:
OPTION CODES
C2L - ROOF PACKAGE
DD8 - OSRV
Last edited by Omega Man; 02-08-2009 at 11:22 PM. Reason: Added additional Information
1 Post
Added additional Information on options and warranty.
Sold for $25K
Sold for $25K
