throttle body is least expensive HP gainer
It appears that a throttle body addition is the cheapest way to add HP to a corvette. I was advised by Anti Venom garage in Florida that a cool air intake will do very little and they are expensive compared to a Vmax modified throttle body. Add LT headers and x-pipe and exhaust, and you have a package that could approach 400 Hp or there abouts.
I don't think you're going to see that much... with just a TB..
Originally Posted by LightFighter_GXP
(Post 1570388052)
If you do a search on here I think you'll find most agree throttle body modifications are worth little to no hp gains, but do improve throttle response appreciably. Cat back exhausts are done for sound and also show little to no hp gain. Headers, high flow cats and X pipe would probably be worth 20 to 30 hp. A good CAI would be a good addition to headers (more air in, more air out, more power), but exact gains are hard to quantify on a dyno because they are so dependent on driving conditions.
HOLY CRAP! :eek: Your gullable!:yesnod: :thumbs:
If TB porting made a much of a difference,,,,dont you think GM would have incorporated it into the the C5??? Lets look at the STOCK HP of a regular C5 coupe or Vert. There have been thousands of dynos of totaly STOCK C5 and they avarage around 320-330 RWHP. Some a little more some a little less. The C5 ZO6 STOCK, gets around 350-360 RWHP. I added the following MODS to my stock 02 ZO6 and had a PROFESSIONAL TUNE done: VARARAM VB2 Ported TB Stainless Works LT SS system. 1 3/4" primary LT headers, Random Tech high flow CATS, 3" mid pipe, 3" X pipe, 3" muffler system Actual Dyno Result = 387 RWHP @ 375 RWTQ Nominal HP gains for these componets on a ZO6: = LT Headers and exhaust system = 15-20 HP Ported TB = 5 HP with better Throttle Response Tune = 10-12 HP If you added the Vmax modified throttle body. LT headers and x-pipe and exhaust, " TO A STOCK C5 " and you have a package that could approach :toetap: 320-330 RWHP + 15-25 HP ------------------- 335 350 RWHP ,,,,,,,,,,on a GOOD DAY:yesnod:,,,,if your stock tune doesnt go to hell:D So,,,that shop sells that VMAX TB ,,,,RIGHT?????:leaving: Please dont fall for the bolt on hype fed to you by the people who sell the stuff. All of this bolt on MOD HP result stuff is VERY WELL documented on this forum. I just spent megga-dollars and installed heads, cam and a ported FAST 90/ported 90mm TB and a professional tune and managed to get to 450 RWHP I did all the works my self plus the porting so, there wasnt any labor cost involved. All that only netted 63 more HP. |
wont see much if any on a TB. Start with a good airbox and a set of headers and a tune and you will see a gain of 35-40 hp.
Originally Posted by Speedvanish
(Post 1570388102)
The TB coupled with the headers, H pipe and indy exhaust would increase the hp substatially, I think.
The dyno tune is the SINGLE biggest HP increaser. Not as sexy as Long Tube Headers and or other parts. the DYNO tune is the KEY to performance |
Originally Posted by AU N EGL
(Post 1570388893)
plus the biggest part is the DYNO TUNE to get it all to work together.
Darn, I just ordered a "Turbinator" from that same shop... ;)
Thee best power adder hands down on a pure stock motor is a:
SuperCharger! gains are well worth the money spent, look @ A&A for a complete smog legal set-up and you'll see 450-480 RWHP on a stock motor, and that includes stock exhaust manifolds and cats w/ aftermarket cat back mufflers - Add headers, Hi-Flow Cats, x-pipe coupled to a good catback exhaust you'll see 500 RWHP - I just seen a member with a stock (everything stock) bolt on Andy's kit and he layed down 510 RWHP with a 3.6" Pulley on a MN6 '01 Coupe! :D Don't waste your money on the claims of the TB, but be assured it will be a heck of alot crisper in throttle response and also remember you will need to have the AIR DEMAND recalibrated for start up so it doesn't rev real high and then come down to regular idle!:D Ask the shop about this :smash: Thanks,Matt |
Originally Posted by madmatt9471
(Post 1570389312)
SuperCharger! gains are well worth the money spent, look @ A&A for a complete smog legal set-up and you'll see 450-480 RWHP on a stock motor, and that includes stock exhaust manifolds and cats w/ aftermarket cat back mufflers - Add headers, Hi-Flow Cats, x-pipe coupled to a good catback exhaust you'll see 500 RWHP - I just seen a member with a stock (everything stock) bolt on Andy's kit and he layed down 510 RWHP with a 3.6" Pulley on a MN6 '01 Coupe! :D Don't waste your money on the claims of the TB, but be assured it will be a heck of alot crisper in throttle response and also remember you will need to have the AIR DEMAND recalibrated for start up so it doesn't rev real high and then come down to regular idle!:D Ask the shop about this :smash: Thanks,Matt Yup, if I could do it all over again, I would have gone with the SC and be done with it, dam bolt ons:banghead: |
Originally Posted by hotwheels57
(Post 1570389114)
(Post 1570389312)
SuperCharger! gains are well worth the money spent, look @ A&A for a complete smog legal set-up and you'll see 450-480 RWHP on a stock motor, and that includes stock exhaust manifolds and cats w/ aftermarket cat back mufflers - Add headers, Hi-Flow Cats, x-pipe coupled to a good catback exhaust you'll see 500 RWHP - I just seen a member with a stock (everything stock) bolt on Andy's kit and he layed down 510 RWHP with a 3.6" Pulley on a MN6 '01 Coupe! :D Don't waste your money on the claims of the TB, but be assured it will be a heck of alot crisper in throttle response and also remember you will need to have the AIR DEMAND recalibrated for start up so it doesn't rev real high and then come down to regular idle!:D Ask the shop about this :smash: Thanks,Matt :iagree: I agree with everything except that the A&A kit is NOT a "smog legal set-up"...only the actual supercharger unit has an EO#. Most smog shops would never know that though. :thumbs: |
You get a whole set of different problems with SC, engine longevity for one. With out forged pistons or the correct rings the engine will wear fast and a head gasket becomes a wear item. I would feel a whole lot better with a iron block for SC. Once again there is a reason the ZR1's engine cost 20K over the counter.
Originally Posted by MTPZ06
(Post 1570395201)
Here is the link:(and what it says check out the bottom :thumbs: ) http://www.vortechsuperchargers.com/product.php?p=102 I do accept appologies in the form of PAYPAL :lol: 1997-2004 Chevrolet Corvette C5 5.7L LS1 Supercharging Systems View larger image Power Torque Stock 345 HP 350 lb/ft Vortech 494 HP* 473 lb/ft* Increase your C5's horsepower from 345 to 494 and torque from 350 lb./ft. to 473 lb./ft.* Quality Features: Vortech gear driven supercharger with SQ technology provides nearly silent operation and unmatched reliability Technologically advanced, high-efficiency impeller and housing design developed in Vortech's supercharger test cell Fuel management upgrade includes high-capacity fuel injectors, and a hand-held ECM re-programmer Integrated air/water, dual-pass charge cooler configuration allows for additional horsepower gains and features maintenance-free design Oil feed and oil drain assemblies deliver the best possible lubrication and cooling for the supercharger, even under sustained boost conditions Retains the stock factory cooling components for OE integrity and the system fits under the stock hood Inlet and discharge duct connections utilize heat resistant silicon sleeves and premium quality stainless steel clamps OEM-type cast aluminum mounting bracket for "factory installed" appearance and rigidity High-flow bypass valve provides surge-free compressor operation Warranty Information 3-Year Supercharger Limited Warranty Included with engine-oil-fed superchargers if purchased with a complete street-legal system. Not available with tuner kits. Available with V-3 systems for an additional $50.00. More information (PDF) . 3-Year/36,000-Mile Powertrain Limited Warranty Available with complete street legal systems sold and installed by a Vortech Top-Tier Installer. Not available with tuner kits. More information . Please Note *Supercharged horsepower and torque data shown is a calculated estimate based on percentage increases from actual rear wheel hp/tq measurements. 50-State Smog Legal Complete systems are smog legal per California Air Resources Board (CARB). CARB EO # D-213-27 Thanks,Matt |
Originally Posted by blue63cpe
(Post 1570395872)
Sure, any time you increase power, whatever the method, there is increased stress on parts. But forced induction is probably the least stressful and most reliable way to obtain a major increase in power, and also maintains the best driveability. |
You can remove all of the material in front of the throttle blade. It doesnt change how much air flows through the blade opening.
Originally Posted by Pwrtrip75
(Post 1570396955)
Originally Posted by jovette
(Post 1570397124)
It does if there were restrictions limiting the amount of airflow to less than maximum capacity of the the throttle body opening prior to removal of said restriction(s):thumbs:
(Post 1570396383)
Okay you might want to re-check the part number on the A&A kits "NOW" look at the number on Votech's site - I just looked into this the other day for my friends C6 and they have the EO and CARB #'s :D
