Anyone Jet hot coat or Powder Coat an LS1/LS6 instake Manifold?
Can this be done? I know you can powder coat with a chromelike color. Has this been done before? I think it would look cool.
Re: Anyone Jet hot coat or Powder Coat an LS1/LS6 instake Manifold? (chuckster)
The intake is plastic. I don't think it can be done. Holly makes
an aluminum intake that I guess could be polished so you could go that route. |
chuckster, hi,
As the LS1/LS6 is built from some sort of reinforced hard PE-/Nylon- compound, you can do coating this intake plenum with many things, i.e. => - plating with Crome - plating with Gold (even 22/24ct) - plating with Nickel - plating with Copper Just go out searching a shop who does galvanic plating process and you are in that Business of enhancements - often much more cheaper as when you purchase the finished parts. I went for this route and am very happy with the results, esp. on board of our Yacht (many Interior outfits as well as in the engine room). Joe. |
Re: Anyone Jet hot coat or Powder Coat an LS1/LS6 instake Manifold? (SwissVette_Joe)
chuckster, hi, As the LS1/LS6 is built from some sort of reinforced hard PE-/Nylon- compound, you can do coating this intake plenum with many things, i.e. => - plating with Crome - plating with Gold (even 22/24ct) - plating with Nickel - plating with Copper Just go out searching a shop who does galvanic plating process and you are in that Business of enhancements - often much more cheaper as when you purchase the finished parts. I went for this route and am very happy with the results, esp. on board of our Yacht (many Interior outfits as well as in the engine room). Joe. I think I'll get the LS6 Intake and have my local plater take care of it. |
