1990 power window motor
can anyone help in power window motor replacement tips i cant get to the darn thing, have new motor but cant figure getting the old one out:willy:
remove:
interior door panel aluminum accessory panel two regulator bolts on top of door two regulator bolts on bottom of door regulator to glass bolts ***tape window to door with window raised so that the glass can't fall into the door regulator assembly from door drill out the rivits that hold the old motor to the regulator replace the rivits with flat headed bolts so that there is no clearance issue with window or use metal brake line and a line flare die to make your own rivits install is reverse of removal fiddle with adjustment to keep the leaks and wind noise out while keeping the window low enough not to smack the paintwork for the next week or so then put the panel back on. |
thanks so much i`ll be working on it today
