1990 power window motor
Old Jul 1, 2009 | 09:36 PM
jdyez's Avatar
jdyez
Default 1990 power window motor
can anyone help in power window motor replacement tips i cant get to the darn thing, have new motor but cant figure getting the old one out
Old Jul 1, 2009 | 09:59 PM
94z07fx3's Avatar
94z07fx3
remove:
interior door panel
aluminum accessory panel
two regulator bolts on top of door
two regulator bolts on bottom of door
regulator to glass bolts
***tape window to door with window raised so that the glass can't fall into the door
regulator assembly from door
drill out the rivits that hold the old motor to the regulator
replace the rivits with flat headed bolts so that there is no clearance issue with window or use metal brake line and a line flare die to make your own rivits
install is reverse of removal
fiddle with adjustment to keep the leaks and wind noise out while keeping the window low enough not to smack the paintwork for the next week or so then put the panel back on.
Old Jul 2, 2009 | 07:46 AM
jdyez's Avatar
jdyez
thanks so much i`ll be working on it today
To 1990 power window motor
