What oil psi is to high?
Oil pressure is 50-60psi at idle and at cruise.
Highly spirited driving the pressure can reach 100 psi. So, what's too high? '09 Z |
At idle mine is around 50 when the oil is cooler and drops to around 30 when the oil temp gets higher. Mine also jumps considerably higher when getting on it.
:cheers: Matt |
Upon cold start it's at 60 psi.
Up to temp at idle mine's at 37-38 psi and add about 10 psi for every 1000 rpm thereafter... :bigears |
Originally Posted by 3LZZ06
(Post 1571168438)
Up to temp at idle mine's at 37-38 psi and add about 10 psi for every 1000 rpm thereafter... :bigears Good rule of thumb to put in the back inner recesses of the mind. I never saw this amount of psi in my '06. That's why I was wondering if 100 psi for a sustained amout of time would pop a gasket. |
Originally Posted by BlaznZ06
(Post 1571168587)
:thumbs: Thanks People
Good rule of thumb to put in the back inner recesses of the mind. I never saw this amount of psi in my '06. That's why I was wondering if 100 psi for a sustained amout of time would pop a gasket. Jim |
Originally Posted by Painrace
(Post 1571168805)
What is your oil temperature? If you have 100 psi at 250 degrees at 3,000 RPM it is too high!
Jim The temps are around 195-210 the RPM's I didn't notice, but I was in third and probably around 90ish mph. The astute wife of my asked me if it should have been that high and when I looked down I took my foot off the gas. I'll get on it today and see the RPMs |
My 08 Z has @ 85 at cold start, on a long trip at 75 MPH the pressure is about 55. Oil temp rarely goes above 185.
:thumbs: |
(Post 1571169188)
Jim
The temps are around 195-210 the RPM's I didn't notice, but I was in third and probably around 90ish mph. The astute wife of my asked me if it should have been that high and when I looked down I took my foot off the gas. I'll get on it today and see the RPMs Thanks BlazinZ... :cheers: |
I just switched to 15W-50 and while i love it on track... the street pressure (driving to/from the event) is freaking me out... I don't like seeing 90-100 PSI so much :(
100-150F: ~75 psi at 2000 rpms :eek: 150-160F: ~75 psi at 4000 rpms 187F: 82psi at 5800 rpms Ambient temp: 70-75 So i figure I have a 300hp Z06 now... as i'm afraid to go over 4500 rpms at my normal oil temps (150-160F) :smash: |
Originally Posted by Dreamin
(Post 1571173336)
100-150F: ~75 psi at 2000 rpms :eek: 150-160F: ~75 psi at 4000 rpms 187F: 82psi at 5800 rpms Ambient temp: 70-75 So i figure I have a 300hp Z06 now... as i'm afraid to go over 4500 rpms at my normal oil temps (150-160F) :smash: Jim |
Same here, cold start 60 psi, but as temps warm up goes down to 35-40 psi idle.
Just depends on temp and weight of oil, obviously higher weight will give higher pressure |
mine is at 63 psi on a cold start, but once the oil temp is at around 175 degrees, the pressure gets down to 34-38psi, and in the mids 80's at WOT
At a cold start I am at about 70psi at idle and then it settles to 60psi pretty quickly. It goes up to almost 70 psi at 2,000 - 3000 rpms until the car is warmed up. Once fully warmed up with oil temps around 180 I am at 26-30psi at idle and around 52 psi at cruising speeds.
Okay
Using AMSoil 10w 30. I tried yesterday to replicate high psi on the highway and couldn't not get the same conditions. This morning on the way to work; 1st gear 30mph 3500rpm Oil psi 100 |
(Post 1571178276)
Okay
Using AMSoil 10w 30. I tried yesterday to replicate high psi on the highway and couldn't not get the same conditions. This morning on the way to work; 1st gear 30mph 3500rpm Oil psi 100 100 psi seems high if at operating temp (175f +-) |
(Post 1571178586)
What's your oil temp at this point...
100 psi seems high if at operating temp (175f +-) Temp should be around 175 I was told this morning by the vette shop that the Z oil filter should take 160-170 before any problems. |
Originally Posted by captain454
(Post 1571176407)
Dreamin'
Here's what you do. Take your car (filled with 15w50) up north and park it in a parking lot in Fairbanks this winter. Start it up at 4AM without letting it warm up, and just hammer the S@#$ out of it straight away, making sure to bounce off the rev-limiter in every gear before shifting. Let me know if everything works out! :willy: |
(Post 1571178781)
Originally Posted by ronsc1985
(Post 1571180612)
That's kind of irrelevant since the oil filter is on the scavenge side of the oil system. The oil pressure reading is taken in an oil gallery after being pressurized by the oil pump. The oil filter never sees the engine bearing/lifter oil pressure.
