fuse box local.
Is there another fuse box on a C-5 other than the one under the hood near the battery?
There is another one on the passenger side floor board. There is a panel that you have to remove to get to it.
Originally Posted by 02MillenniumVette
(Post 1571592445)
Here you go:
Instrument Panel Fuse Block The instrument panel fuse block is located on the passenger’s side of the vehicle, under the instrument panel and under the toe-board. Remove the carpet and toe-board covering to access the fuse block by lifting up on the latches at the top of each corner of the panel. Then turn the fuse block door knob counterclockwise and pull the door to access the fuses. Minifuse Usage 1 Console Cigarette Lighter 2 Monitored (Inadvertent) Load Control 3 Lumbar Seat 4 Driver Seat Control Module 5 Radio, Compact Disc Player 6 Parking Lamps, Taillamps 7 Cigarette Lighter 8 Stoplamp, Hazard Flashers 9 Body Control Module 10 Windshield Wiper/Washer 11 Accessory Power 12 Blank 13 Body Control Module - Ignition 1 14 Crank 15 Hazard/Turn Signal 16 Air Bag 17 Tonneau Release 18 HVAC Controls 19 Instrument Panel Control 20 Cruise Control 21 Automatic Transmission Shift Lock Control System and Inside Rearview Mirror 22 Body Control Module - Ignition 3 23 Body Control Module - Ignition 2 24 Radio Antenna 25 Body Control Module - Ignition 1, Instrument Panel Control 26 Hatch/Trunk Release 27 HVAC Controls 28 Bose Speakers 29 Diagnostic 30 Right Door Control Module 31 Power Feed Door Right 32 Fuel Tank Door 33 Door Control Module Left 34 Power Feed Door Left Circuit Breaker Usage 35 Driver Power Seat 36 Passenger Power Seat Micro Relay Usage 37 Monitored (Inadvertent) Load Control 38 Right Daytime Running Lamp 39 Hatch/Trunk Release 40 Left Daytime Running Lamp 41 Tonneau Release 42 Courtesy Lamps 43 Automatic Lamp Control Parking Lamps 44 Automatic Lamp Control Headlamps Mini Relay Usage 45 Bose Speakers 46 Rear Defogger Maxifuse Usage 47 Ignition 1 48 Rear Defogger 49 Blank 50 Ignition 2 51 Blower Motor 52 Starter 53 Blank 54 Headlamps Engine Compartment Fuse Block There is one fuse block in the engine compartment located on the passenger’s side of the vehicle in front of the battery. To remove the fuse block cover, turn the knob counterclockwise. Minifuse Usage 1 Rear Fog Lamp 2 Approach 3 Right Headlamp Motor 4 Left Headlamp Motor 5 Anti-Lock Brakes, Selective Real Time Damping 6 Fog Lamp 7 Selective Real Time Damping Relay 8 Headlamp Low-Beam Right 9 Headlamp High-Beam Right 10 Headlamp Low-Beam Left 11 Horn 12 Headlamp High-Beam Left 13 Fuel Pump 14 Cooling Fan - Ignition 3 15 Oxygen Sensor 16 Powertrain Control Module 17 Throttle Control 18 Injector 2 19 Engine Ignition 20 Blank 21 Blank 22 Injector 1 23 Powertrain Control Module 24 Air Conditioning 25 Blank 26 Blank 27 Spare 28 Spare 29 Spare 30 Spare 31 Spare 32 Spare Micro Relay Usage 33 Air Pump 34 Air Conditioner and Clutch 35 Fuel Pump 36 Horn 37 Rear Fog Lamp 38 Back-Up Lamps 39 Fog Lamp 40 Blank 41 Selective Real Time Damping Mini Relay Usage 42 Ignition 1 43 Cooling Fan 2 44 Cooling Fan 3 45 Cooling Fan 1 Maxi-Fuse Usage 46 Cooling Fan 2 47 Blank 48 Blank 49 Cooling Fan 1 50 Air Pump 51 Blank 52 Anti-Lock Brakes 53 Selective Real Time Damping Electronics 54 Fuse Puller |
Thanks for the info guys,I want to hard wire my Radar det. and am tring to figure out the easiest way,I bought one of those pigtail plugs that go into the rearview mirror and it didn't quite make good contact so I put a little silicone on it to make a tight connection,well the radar fell away from the windshield and pulled the wires loose and they can't be reinserted,sooooooooo the next step for power is hardwire to something,any suggestions?
3 Attachment(s)
You have a couple of options to get an additional switched acc power source
The easiest is to use fuse #22 which is live but not used for any other function. I used an “add a circuit” connector to hook in. This gives you the switched hot. Attachment 48158099 These are not my pics but show you the hook ups Attachment 48158100 You can see how the connectors slot into the fuse box/ The other option is to hook up into the spare connector which is available for ancillary devices. I believe this is used for the CD changer so it may not be an option for you if you have one of those fitted. In the passenger footwell (unless you have a 2004) behind the kick board you’ll see a fuse block and to its left a silver box which is the BCM. There are three wires taped together feeding into a connector. The Black wire is ground; the Orange wire is powered through fuse #7 but is permanent hot. The Yellow wire is powered through fuse #11 and is switched hot when the key is in the ACC or ON positions. Hook up to the Yellow for switched ACC. Attachment 48158101 |
Did you trim the lugs that plug into the fuse box? Or am I missing something here? I just bought one of these and it definitely will not fit the two slots in fuse # 22.
DeeGee - What is unique on the 04s? I am looking for the best place to hook into an always hot 12 volt source in the interior.
[QUOTE=DeeGee;1571594201] In the passenger footwell (unless you have a 2004) behind the kick board you’ll see a fuse block and to its left a silver box which is the BCM. There are three wires taped together feeding into a connector. |
I believe there is an always hot in the HVAC controls. (I have dual zone)....if my memory is correct. Just use a meter and you'll find it. For switched power, i tapped into a wire at the ignition.
Originally Posted by Sailon
(Post 1572583209)
IIRC the 04s dont have the connector in the pic I posted. You'd need to tap into another circuit or run a wire to the battery through the firewall. The cigar lighter is always hot |
Thanks AntonioZ06 and DeeGee!
Originally Posted by DeeGee
(Post 1571594201)
The easiest is to use fuse #22 which is live but not used for any other function. I used an “add a circuit” connector to hook in. This gives you the switched hot. http://img.photobucket.com/albums/v2...Circuitpic.jpg These are not my pics but show you the hook ups http://img.photobucket.com/albums/v2...Connection.jpg You can see how the connectors slot into the fuse box/ The other option is to hook up into the spare connector which is available for ancillary devices. I believe this is used for the CD changer so it may not be an option for you if you have one of those fitted. In the passenger footwell (unless you have a 2004) behind the kick board you’ll see a fuse block and to its left a silver box which is the BCM. There are three wires taped together feeding into a connector. The Black wire is ground; the Orange wire is powered through fuse #7 but is permanent hot. The Yellow wire is powered through fuse #11 and is switched hot when the key is in the ACC or ON positions. Hook up to the Yellow for switched ACC. http://img.photobucket.com/albums/v2...tchedPower.jpg You mention the Orange wire goes to Fuse 7, and someone posted above that 7 is the cigarette lighter. So, if I were to cut the orange wire and splice the end that's coming to the the fusebox into the yellow wire, would I think get a cigarette lighter that is switched by accessory power? |
Thanks for bringing this post back - been wondering how to connect some stuff up and was looking for a switched place to do it.
Originally Posted by 8VETTE7
(Post 1581717094)
Not DeeGee here but the answer is YES. Be sure to tape over the end of the orange wire that you cut so that it doesn't touch any metal and pop a fuse.
Fuse box
Yes. It's under the driver side dash. On the floor below the heater coil. Lift the rug and you will see the box Bolted to the floor.
Originally Posted by C5-JDvette
(Post 1581722608)
Instead of just cutting the orange wire and tapping into a splice in the yellow wire, I think I am going to protected spade plugs on both ends of the orange wire, and tap a spade onto the yellow wire. That way, not only will I protect the end of the orange wire, I'll also be able easily swap back in the future, should I ever want to. And, if I want to add anything else, I'd have both type of power already tapped. ;-)
Edit: After looking at the connector firsthand, the orange wire does not connect to the cigarette lighter. Details here: http://forums.corvetteforum.com/c5-g...post1581724003 |
Can I pull the cabihn fuse box? If so, how?
(Post 1571594012)
Here you go:
Instrument Panel Fuse Block The instrument panel fuse block is located on the passenger’s side of the vehicle, under the instrument panel and under the toe-board. Remove the carpet and toe-board covering to access the fuse block by lifting up on the latches at the top of each corner of the panel. Then turn the fuse block door knob counterclockwise and pull the door to access the fuses. A prior installer located electronics for a sub-woofer behind the box just left of the cabin fuse box, then apparently got the electrical power by tapping into the fuses in this box. Problem is, I can't tell where, and the wiring looks like it runs behind the box. I am doing a stereo upgrade and one of my objectives is to rid my C5 of all the "old" installed stuff. So I'd like to pull the fuse box, if that's possible, and see just what was installed and, if possible, figure out how to remove it. Anyone who can add insight how to pull this fuse box from its brackets - please chime in. Thanks, The Lizzard |
