pulley for the ysi blower??
where can i buy a 2.50 8 rib pulley with the slashes for extra belt grip for the vortech ysi blower with andy's A&A kit? ive tried one shop but they are extremely hard to do business with and would rather not name them. any ideas would be appreciated!!!
Also try Greg at blowerworks.net. Greg recently made a slotted pulley for my ECS Paxton Novi 1500. Greg can send you pics.
You will be way over the max RPM of that blower with a 2.5" pulley, just an FYI. :thumbs:
Originally Posted by DOUG @ ECS
(Post 1573191155)
The belt tension is also over 1500lbs so it is almost guaranteed to slip. |
Originally Posted by deviant1
(Post 1573189193)
Arun told me not to use the Reichard style pulley because you'll have to pull really high tension on the belt to minimize slip. A Reichard will shred a highly tensioned belt. Arun recommended a smooth head pulley and high tension. Arun ran a 10-rib and a 2.7" or 2.75" pulley. I started with a 3.3", now with a 3.1" pulley on YSi on A&A. Next is a 2.9" - all Reichard. Next one to buy will be a smooth 2.7". :cheers: |
you can also try aspracing.com for pulleys.
(Post 1573191155)
The Mustang guys tell me the YSi starts to really shine at about 80,000 rpm! :smash::eek::D:yesnod: :cheers: |
i have the 2.70 on there now and am not seeing more than 14 lbs of boost, it has the 10% innovative crank balancer pulley, my compression is at 8.8-1 i finally got hold of reichard racing and the pulley will be shipped out tommorow, thanks guys
Originally Posted by TRIZ
(Post 1573191516)
Doug,
The Mustang guys tell me the YSi starts to really shine at about 80,000 rpm! :smash::eek::D:yesnod: :cheers: (but I have an easier time getting them fixed if they break) :cheers:
(Post 1573195561)
Do you have a stock tensioner on the car? |
(Post 1573199066)
Yeah I have been known to overspin a head unit or two also. :lol:
(but I have an easier time getting them fixed if they break) :cheers: You must have belt slip already, you should be making a lot more then 14lbs with that combo. Good luck with your build Do you have a stock tensioner on the car? |
What is the engine combo Deviant1? CID/topend?
(Post 1573195561)
Originally Posted by Frans96ss
(Post 1573200478)
We have a 2.75 with stock diam. crank pulley and we make alittle over 16psi on a 434Cu in. We use Reichard racing pulley also with ALOT of tension and it works fine.
its a stock block 427, stock crank, diamond low comp pistons, stock heads ported, andy's a&a 8 rib ysi, innovative 10% bigger balancer pulley setup, meth, 80 lb injectors etc....
(Post 1573201179)
:cheers: |
negative no slip i am using the reichard racing pulley and not even a gatorback belt, just a regular goodyear belt!!!
(Post 1573207829)
Wonder what a YSI/427ci and a 10% OD with a 2.7 blower pulley and the flip drive would make?
got any HPTuner logs you can post? i want to see that MAP line. i still bet slip.
-Carl |
