Power antenna FRC vs Conv.
Hello,
What is the difference between a Powered antenna for a FRC (Z06) and one for a Convert ? Thanx mimi |
Originally Posted by mimi77230
(Post 1573943431)
Hello,
Originally Posted by IRACEMYCOPCAR
(Post 1573945280)
The ZO6 doesnt have a power antenna.
FRC and Convt looks to have the same rear body panel so why antenna are different ? |
No difference...........
Who says they are not the same?
I've installed four GM power antenna into FRC/Z06es. This is the kit I usedhttp://www.ecklers.com/product.asp?p...dept%5Fid=1424 Here is a copy of the install instructions:http://content.madirect.com/pdf/607083.pdf The kits are the same from both Eckler's and Mid America but I think Mid America was cheaper. Only difference was I installed a switch in the power lead so the anntena would not go up when the CD player is used. |
Hi,
thanx for links but please have a look here : http://www.mamotorworks.com/corvette?frame=2.9152 One is for FRC (Z06) and the other for Convertible (even if no longer available) The only visual difference looks to be the bracket and additional wiring. I also found : http://www.parts123.com/parts123/yb....Z5Z5Z500000509 http://www.parts123.com/parts123/yb....Z5Z5Z500000509 [http://www.gmpartshouseusa.com/partl...layCatalogid=0 Do you have a GM part number ? Thanks mimi |
The Z06 may not come with one, but the wiring and the mounting is there for it.
I installed the GM one in mine with no problem. |
Originally Posted by heavymetals
(Post 1573955085)
I installed the GM one in mine with no problem. Did you just follow the Mid America installation instructions? |
(Post 1573955085)
I installed the GM one in mine with no problem. Hi, :"...but the wiring and the mounting is there for it" What do u mean exactly ? Do u have a GM part number ? Thanx mimi |
Originally Posted by BUGZ
(Post 1573957915)
You can even buy a switch to defeat the auto deployment, but when I swapped out the radio it has that option built in. http://www.mamotorworks.com/corvette-2-308-9152.html The mounting bracket anchor and the ant wiring (DUH) are already in the car., but you have to run the trigger and power & ground (big deal) to the box under the carpet and a ground. Install is DUCK SOUP. You just have to remove a taillight or two. |
Did the same to my 03Z got a GM vert antenna and installed like a charm and would never go back!!!!!
