Antenna cable.Where to place the grommet in the left rear wheel well?
When drilling a hole to the grommet i want it to be in the right place.
My car have a radio but no antenna cable from the radio to the antenna. Can sombody post a picture of where the grommet is placed in the left rear wheel well?:flag: |
On my 65, the antenna cable uses the same grommet as the rear wiring harness, so you shouldn't need to drill another hole.
I have to go out to the garage and have a look again:flag:
You access it from the left rear wheel well? I got to take the wheel off because i cant see it with wheel on the car. I thought it was down besides the metal plate(body bolts)in front of the rear wheel. I am wrong there i see. |
Here's a photo of my 65
http://i278.photobucket.com/albums/k...te/Antenna.jpg |
Thanks a lot. The picture is taken right under where the antenna mount to the body?
Thanks a lot. The picture is taken right under where the antenna mount to the body and you have to take off the left rear wheel to access it?
Originally Posted by TheSaint
(Post 1573955804)
Great. Thank you a lot 62Jeff:thumbs::)
You are quite welcome :cheers:
See your Assembly Manual, section U69, sheet 4.00, and UPC 12, sheet C5, item #1; the main wire harness and the antenna cable use the same grommet at the lower outboard corner of the vertical rear bulkhead. :thumbs:
1 Attachment(s)
The attached pic shows the location of the grommet in question from inside the car (65 coupe in this case). As Jeff indicated above, it's a two-hole grommet for the cable and the harness. If you get a new one, just use a good razor blade and make clean cuts in from the edge to the holes to slip the wires into the grommet.
Dave Z |
here's a shot off my late '65. Looks like grommet was installed from the rear (agrees with the bevel edge in Dave Z's pic). View is looking up vertically; you can see the antenna hole on the rear deck.
http://i47.photobucket.com/albums/f1...pics/P_ant.jpg |
Thanks for all your help my friends:thumbs::flag:
