Sidepipes and Angle plug heads
Was looking at the Hooker site and noticed that it says their pipes won't fit with angle plug heads.
Anyone tried this? :cry |
Re: Sidepipes and Angle plug heads (72rdstr)
I have them both, last time I looked it all fit :lol: :cheers:
Hi, a member by the name PASO has this set up.....he may have some information that is of some use to you? I hope this helps.
Re: Sidepipes and Angle plug heads (Darcy Bast)
Depends on the heads...I have Trick Flow 23 degree angled heads and my Hooker side pipe headers fit fine. Call and talk to the people
Neil in Tenn |
Re: Sidepipes and Angle plug heads (Nomad78SA)
I have GM Heads 882's with angle plugs and like most guy's that will answer you will tell you only one or two plugs will be a little harder to get out. Also as mentioned above it will depend on what head you have. I was going to advise Hooker that they should remove that disclaimer as it' is not real accurate. Here you can see the first plug is a little tough.https://temp.corvetteforum.net/c3/pa...0-0020_img.jpg https://temp.corvetteforum.net/c3/pa...0-0019_img.jpg
I've got the Hooker sidepipe headers with AFR L98 angle plug heads and they fit without any real problems. Like most, the #2 boot is pretty close, but it is not a problem.
