C6 HVAC Mode Door - How Common?
2005 C6 Coupe HVAC Mode door Problem
Finally the passenger side HVAC completely stopped working but emitting really hot air. No mode operation for some time, thought I could live with the issue and the outside condensation would go away if you fine tuned the temp so it was not too cold blowing on the windshield from inside. Now can't live with the blast of hot air from the right. Funny, the left, driver side, works but no mode change. Took it to Tony and he researched it and the mode door apparently is shot, the actuators seem to be spinning but may need replacing while he is in there since it will need the dash mostly disassembled. Told him to replace all the actuators while he has the dash torn down. Will keep updating findings. There isn't much information out there on the mode door for C6s and the dealers don't have the part in stock so it would appear that it is not common, but, I am thinking it may be more common since you wouldn't notice if you had the top off or the vert top down and since a lot of vettes are only taken out of the garage, washed and returned to the garage, there isn't much time to notice. There may be a lot of folks that either don't notice or just live with the problem since the default position works after a fashion. Is this a sleeping problem that is waking up, since mine is a 2005? |
It seemed more common on the C5's, but maybe that's because there were more of them and they are getting older.
In the last year, I've heard of a couple on the C6. It's said to be a difficult and time-consuming ($$$) project to replace one, so your idea to replace all might be a good one. Good luck, and please keep us posted. |
Glad I purchased the GMPP Extended warranty. I haven't had to do it, but for these specific scenarios, I'd rather pay the warranty than the labor work.
The mode door on my C6 is working fine but I had to have the job done on my F-150. The job on the F-150 was no where near the nightmare that it is on the C6.
So what color is the mode door on your C6? You may be looking at a replacement if it is orange. The newer part has a gray material that feels like it is more substantial.
http://forums.corvetteforum.com/pict...ictureid=67387 |
I believe GM's service notes to the dealer technicians indicates to replace all actuators....as long as the dash is apart.
If I can find the bulletin, I'll post it. |
Originally Posted by RnLi
(Post 1575993056)
Don't know how common a problem it really is but it happened to my '05 last summer. Had to have the dash pulled apart to replace all 4 actuators and a shredded mode door that looked exactly like the one posted here. It would have been about a $1000 job if the car were to be out of warranty.
And yes, the old mode door was orange and the replacement was grey, so it appears that they "may" have started using a different material. Of course it could also just be a different color of exactly the same stuff causing me do do it again in 5 more years.:( B |
Originally Posted by Wilzer
(Post 1575992713)
Someone can correct me if I am wrong, but from what I understand, yes, the dash must be taken apart. It was when they repaired the mode door on my '05. The cost, had it not been under warranty, would have been about $1000 at my dealer up here in Canada.
B |
Somewhat common on the early 05's. Door material was defective. I had mine done 4 years ago under ext. warranty ($1550) I paid the ded. of $100 and again this past January at my expense, $1770. Anyone with an early 05 having this problem should contact their dealer and in turn have them contact Delphi the HVAC GM supplier. There is a very good chance that they will pay for full repairs even if there in no longer a warranty. Delphi returned my call long after I had the work done by a non dealer.
I have name and phone # of Delphi. PM if you need it. |
Originally Posted by c6vette
(Post 1584184187)
Originally Posted by laticsfan
(Post 1587653212)
I have an 09 coupe and have the same issue. Only getting heat from the right side. Left side is fine. Pulling the fuses fixes it temporarily but the problem comes back. Did Delphi re-emburse you for the money you paid second time to have the car repaired?
Mode Valve part number...
Originally Posted by Prodago
(Post 1584176845)
Do you have to remove the dash to replace the mode door??
Does anyone have the GM part number for the replacement that folks talked about. Thanks in advance... |
Originally Posted by blanz
(Post 1598284345)
Looks like my '05 HVAC mode door has bitten the dust.
Does anyone have the GM part number for the replacement that folks talked about. Thanks in advance... https://cimg3.ibsrv.net/gimg/www.cor...4ade6bdbe4.jpg This is the part picture from Rock Auto which calls it a mode door. and AC delco calls it heater blend door. AC Delco part # 1550692 |
You da Man!
Thanks so much!!! |
