Hardware Suggestions for 54 Hardtop
I have what I believe to be a Scott top for my 54. (I frankly do not know how to tell the difference between a Plasticon and Scott top.) Anyway, it came with no hardware or hold down brackets of any kind. I am desperately seeking suggestions. Thank you much!!
Typically they used 4 of the 53-55 front convertible top chrome latches that hooked to the windshield. In some cases the center J shaped piece may have been longer than the OEM part. (I happen to have an extra pair if interested.) Send me your email and I can forward some photos showing the latches on my hardtops.
I have the female mounts for the scott top that attach to the 53-55 body. The parts on the top itself are basically straight pins that slide into these. I do not have the male portions.
I've seen various hardware used on the Scott top , you may wont to make up something that works for you .The header is the hard area to hold down . The plasticon top is better and having a big back window ,also water tight . I used it mostly in the winter .
http://i112.photobucket.com/albums/n...s/DSC02737.jpg |
Hardtop
Originally Posted by 1955 copper
(Post 1576251457)
Dan my brother-in-law for a while repro'ed the plasticon tops. He used my original to make a mould but the original dint fit good around the window area and the hardware mounts I dint like .So he made the window area fit perfect and we came up with using "U" hardware bonded to the top as seen here so straps could be used to pull and tighten the top down . I added 56 hard top retainers plate to support the fiberglass as seen also . Easy on and off. The inner liner is all biege leather .Any questions ask me. :thumbs:
http://i112.photobucket.com/albums/n...hevy/NCRS6.jpg |
Originally Posted by BJ Retired
(Post 1576251545)
Roy any chance of posting a few Picks of your hold down straps. They are pretty strong. Plasticon hardtops have a bad habit of going air born at high speeds when the original hold downs are used............Bob
(Post 1576252247)
Next time you come over I'll show how it works because I had the bubble top on when you come. How is that fender doing? :cheers:
Originally Posted by redneckriviera
(Post 1576248744)
Russ http://www.earlycorvettes.com/chatgr...op/53top-1.jpg http://www.earlycorvettes.com/chatgr...op/53top-2.jpg http://www.earlycorvettes.com/chatgr...op/53top-3.jpg http://www.earlycorvettes.com/chatgr...op/53top-4.jpg http://www.earlycorvettes.com/chatgr...op/53top-5.jpg http://www.earlycorvettes.com/chatgr...op/53top-6.jpg |
Thanks for the pictures and information guys. I've got a 54 with a strange hardtop (it's not like the ones seen above, closest it would be to Scott top) and it's got no mounting hardware left. :cheers:
OMG! Turn buckles and a 3rd brake light. I know, they were just cars back then. :yesnod: :cheers:
(Post 1576248744)
Scott Top
I Have a Scott Top
A Hard Top any ides on where to get weather stripping for it? Dan:willy: |
Originally Posted by scopeli
(Post 1576263382)
we need to see the inside of the front of your top to help you. it will determine where brackets are to be placed. the easiest and most secure way of supporting the top will involve four 1/4" x 5" studs with at least two inches of thread, four angles at least 1/8" x 1" x 1" and four 1/4" thumbscrew(nuts). the back of the top will mount the same on almost any top. the angles will need to be predrilled on both sides. installation involves drilling through the side of the top and mounting a angle clip on the inside. you can cap the head of the bolt on the outside of the top (which will resemble the the plasicon emblem on the side) or use a bolt with a chrome plated head. next take the stud approximately three inches from the threaded end and bend the rod so it resembles the J bolt used on front of the convertible top. the threaded part goes through the angle and you attach the thumbscrew(nut). a piece like roy posted can mounted on the deck area of the car and the j end will catch on it. the thumb screws enables you to put this top on with no tools and they can be taken off when you are installing the top so that you don't scratch the paint. the front is fastenned the same way, except you do not drill through the hood. top can be installed in a matter of minutes by yourself with no tools and no fear of scratching paint. if a member is willing to give me his email address i can send him pictures and he can post them. i am lost when it comes to posting pictures.
Originally Posted by JoeNavy1990
(Post 1601468604)
Older thread but offer to share pics is still valid—I can send an e-mail.
Thank you. |
You are responding to your own post here, which was made after nearly a decade.
if there’s individuals you are wanting to reach, try a PM or post a new thread as a new question won’t been seen tacked into an old thread started in 2010. |
