Uh oh...I think my slave cylinder is leaking :(
Well I jacked up my car to change the oil today and I see some fluid under the car. No worries I figured, it must be just water. Then I looked at the back of the motor and I realize it's covered in some kind of fluid.
I did the "taste test" and it definitely wasn't water. Only thing I can think of from back there is brake fluid, meaning my slave cylinder took a dump is what I'm guessing. Perfect timing too, I was going to drive my car down to Texas tomorrow. Now I don't think it will make it. I'm kind of screwed because I am moving to Florida in 5 days. Here are some pics, tell me what you guys think: http://i52.photobucket.com/albums/g2...n/bb753f80.jpg http://i52.photobucket.com/albums/g2...n/e18a3640.jpg |
rear main seal? sure that not motor oil?
does the peddle feel ok? or do you have to pump it up to get it to wk |
I can install the new slave for you at Joshs house. Hes got a lift and tools. We will just push his car off it. should not take too long.
Wouldn't it make sense to do everything in the bell housing?? Clutch/slave/throw out bearing???
Originally Posted by k0ts
(Post 1576821311)
Clutch and slave are only 2 years old at the max, I did the Textralia clutch in 2009 I just cant remember when...
I'm gonna go take a test drive and see how bad it's leaking, I don't think it's too bad. |
Originally Posted by Milan
(Post 1576821507)
Originally Posted by lucky131969
(Post 1576821764)
Did you check the master for fluid loss?
Just went and drove it and came back and parked and it's definitely leaking drops. I'm not sure how bad it is yet I'll go back and check under there in a few hours and recheck the master too |
(Post 1576822220)
I'm not sure how bad it is yet.....
So now the question is if it's dripping fast enough to keep me from getting to Texas without it losing all its fluid.
Obviously I can stop and refill it every hour if I need to. |
Originally Posted by Slow Z06
(Post 1576821114)
(Post 1576822338)
(Post 1576822338)
Obviously I can stop and refill it every hour if I need to. see ya tomrrow night |
I wouldn't have any issue with that trip as much of it is highway miles without the need for clutch usage. Fill the res at each fuel stop and you should be good :thumbs:
Originally Posted by a/c man
(Post 1576822408)
I have drove without the clutch in my 2001 z06. only problem is when you stop at the lights:ack: I had to turn off the motor and crank it in 1ST! and go!!:willy:
:rock: |
(Post 1576822408)
just dont get stuck in traffic |
does it feel like brake fluid? I mean oil and brake fluid have a very different feel if you rub them between your fingers.
Mine decided to randomly take a dump back this fall and did the same thing. Found a big puddle under teh car and when I tried to move the car the pedal would just stick to the floor. |
Definitely not oil...throwing it on the lift today to see what's up
the other thing to consider if driving it with the slave leaking is getting fluid all over your clutch -- not a good thing.
K guys starting to pull everying out right now. What all should I replace while I'm in there?
Here's what I'm thinking: Slave cylinder Pilot bearing Throw out bearing Anything else while I got everything off? |
