VS402 Stroker A&A YSI Build near completion
Good luck, as this has been a long time coming for you.
lookin good....enjoy it.
:rock:
Get
...r
...done
That is all.
:willy:
:thumbs: to the OP :D |
"Any ideas for a custom billet badge for the hinny?"
Dragon slayer..... Hope this motor combo gets the numbers you are after. Best of luck. |
:toetap: :lurk:
Originally Posted by Res1cue
(Post 1577226371)
Dude, not cool....
Originally Posted by edcmat-l1
(Post 1577227899)
:toetap: :lurk:
no catch can? hmm
Originally Posted by carlrx7
(Post 1577228335)
no catch can? hmm
You will need a catch can trust me. That crank case pressure will let you know and so will the oil around the valve covers and oil pan. Morosso (sp) is the one to get.
Originally Posted by BADZ
(Post 1577231036)
Yes and it did not work for me. You have to think that if your running at a higher boost level that the pressure will build. These are just little things you will find when your doing this type of build. Good luck.
I had to tap both my katech valve covers with -10 fittings and tubing back to the can with a vent on top. My problems were solved at that point. |
lookin' good
(Post 1577228109)
I know, soon.........
