1981 heater core
What all do I need to remove inside my 81 to get to the heater core. I have a leaker.
I'm not afraid of the work, I just hesitate when the dash is involved. I have a 81 in really solid shape. Can I get by with just taking the glove box door and liner out? Anybody know?? |
WOW....when I did mine I had the entire dash out as part of my restoration....but from what I remember...there would not be enough room to remove the cover through the glove box.
I think you have to have the dash out. Good luck on this one. |
The entire dash does not have to be removed, just loosened on the passenger's side.
But, there is quite a bit to remove to get to that point. Following is a step-by-step that I used a few years back. http://www.bkp944.com/corvette/Heater Core Removal.pdf I can't take credit for the instructions and I can't remember where I downloaded them. My apologies to the original author! -Brian |
I just did mine and I went in from the front engine compartment, no need to remove dash or anything. I will load up some photos if you need to see how its done. PS : I do not have air ,if you do it may be a problem , not sure where air unit is on yours if you have it.
dariopop, I DO have air, so there is quite a large exchanger box in the engine compartment. I'll seek advice from above and give it a shot. Thanks to Brian P for his instructions, this will help!
The instructions would not load for some reason. I cut a pasted as well with no luck. Anything else?
Thanks Brian. |
That's a fun job. I have some pictures when I did my 81...if you want them I can email them to you. I also had an instruction sheet but I don't know where that is at the moment.
Originally Posted by Papsdream
(Post 1577229543)
Thanks Brian. http://www.bkp944.com/corvette/HeaterCoreRemoval.pdf Hope this works better! -Brian |
Thanks, that worked. Wow sounds like a job and 1/2. Hope it all goes well.
